Roaring/Growling when putting into Drive - not bearings
We were having the roaring issue so we took it to the shop. They said it was the front left wheel bearing (again). Instead of paying the unreal price of $400, I did the job myself. I ended up replacing the whole hub assembly and put it back together. I also replaced both struts while I was at it.
Now, the noise is even worse. My wife and I narrowed it down the simple fact of putting the car in Drive creates the noise. I had her drive past me many times and I can't hear any noise from the wheels or anything, the noise is heard in the cabin though. So, I decided to put it into 4x4 and backed out of the driveway. She REALLY made some noise now!. Also, it actually stopped at the bottom of the driveway and I didnt want to put more gas on it as I didnt want to break something. I put a bit but not much.
So, I'm wondering, is it the tranny, transaxle, transfer case, etc?
Any help would be appreciated.
Brian
Brian
Need some more info about the noise...
Does the noise change in relation to engine speed? Vehicle speed? Neither?
When you say it happens just by putting it in drive, does that mean you get the noise without the vehicle moving at all? Are you sure it's not a loose heat sheild or exhaust?
Maybe sem like dumb questions, but w/o being able to hear the noise you got to ask...
Sorry about that as I forgot to answer that question.
The vehicle does not have to be in motion. In fact, as soon as you place it into Drive, it starts. You can hold the brake and press the gas and she gets louder. She also gets louder driving it. What's kinda strange is it doesnt make much noise going in reverse.
You got something weird going on there. You might try a mechanics stethoscope to further id where the sound is coming from. A little baffling to have a sound coming from a drive train component when the vehicle is not moving, it almost has to be something loose that is making noise due to vibration, unless there is something driven in there when the vehicle is stopped that I'm not aware of (and I'm no expert on the Escape tranny/transfer case)
OK...it just got interesting.
I took the wheel hub off the passenger side since this is where I did most of the work. I only replaced the struts on the driver's side. Anyway, I take her off, place the car into drive and the axle turns. I read up on the different models as I have the 4X4. They offered a front wheel drive and a 4x4 in 2002. Aparently, it's essentialy a front wheel drive with the rears kicking in when going into 4 wheel. I had assumed it was a rear wheel drive. Geez...you think I would know the car better.
So, with the hub off, we still cannot hear any noise from the outside, only from the cabin. I took a pry bar and applied pressure on the exhaust, heat shield, etc to see if the growling from within the cabin would go away. No luck.
The only thing I can think of is the transaxle. I'm going to pull that axle tomorrow and see if the teeth are ok and such.
Any thoughts?
TIA,
Brian
Any thoughts?
TIA,
Brian
Yes, I'm not sure about now, but when we got our Escape it was the only SUV that was FWD when in 2WD and the rears engaged for 4WD.
But you got me baffled still. I'm still betting that it's some thing loose that vibrating - but what could be doing that that you'd only hear inside, I don't know. It'll be interesting to see what this turns out to be...
