Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-20-2007, 03:32 PM
mrwolf mrwolf is offline
Garage is empty, add now
mrwolf is starting off with a positive reputation.
Propane setup Help???
I have this F700 truck I bought and it is running on propane.
It appears to be hooked up the gas tank as well.
Since I have never had a dual fuel truck before I was just wondering
how do you switch from propane to gasoline and vise versa.
There does not appear to be a switch anywhere.
can anyone let me know how this type of system works since I think
the timing has to be changed also if I remember right
Thanks
  #2 (permalink)
Old 10-21-2007, 08:09 PM
thosfsull thosfsull is offline
thosfsull is starting off with a positive reputation.
There might be a dual curve distributor like box sitting somewhere, looking MAYBE like a tin of altoids or two in size, shape, and color....
I just got a dedicated LPG 1997 F-700 last weekend with a 429. I ran out of the propane and was forced to convert back to gas on the spot for $300 in parts.
  #3 (permalink)
Old 10-22-2007, 09:13 AM
Mine is a 1995 F-700 with a 429
there has been a couple times when It just would not start so I want to be able to switch it back to gasoline when this happens and also propane dealers are rare where I am so being able to change it back and fourth would be great.
What parts were involved in changing back to gasoline?
  #4 (permalink)
Old 10-22-2007, 10:51 AM
gasman6674's Avatar
gasman6674 gasman6674 is offline
1996 Ford F-350
gasman6674 is starting off with a positive reputation.
If you will send me a digital picture of the motor's lp equipment I can probaly tell you what to remove. If it has a dual curve on it you will have to remove it also and re-set the base timing. I have not seen to many 429's on dual fuel due to air flow issues.
Let me know
Regards
Gasman
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
Tags
ford, propane, sale, set, setup, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
