Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 10-19-2007, 08:47 PM
councillor councillor is offline
Garage is empty, add now
councillor is starting off with a positive reputation.
I need to remove the drivers-door panel?
How easy or hard is it...??
  #2 (permalink)
Old 10-19-2007, 09:07 PM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
SECTION 501-05: Interior Trim and Ornamentation
1999 F-150/250 Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 02/03/1999
Trim Panel—Front Door
****** content="Trim Panel—Front Door" name=tps_proctitle>Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the front door trim moulding.
Click the image to open in full size.
  1. NOTE: Use the notch to remove the component.
    Remove the inside door handle finish panel.
  1. If equipped, remove the window regulator switch plate (14524).
    1. Lift the front of the window regulator switch plate.
    1. Disconnect the electrical connectors.
  1. If equipped, remove the window regulator handle (23342).
    1. Separate the handle cover from the handle.
    1. Remove the screw.
    1. Remove the window regulator handle.
    1. Remove the spacer.
  1. CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
    Remove the front door panel.
    1. Remove the screws.
    1. Lift and remove the front door trim panel.
  1. If equipped, twist the courtesy lamp bulb socket one quarter turn and remove the socket from the front door trim panel.
Installation
  1. NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
    To install, reverse the removal procedure.
Hope that helps.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
  #3 (permalink)
Old 10-19-2007, 11:41 PM
Stewart:
U the man, thanks again for your help.
  #4 (permalink)
Old 10-20-2007, 12:07 AM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Yer welcome!
Stewart
__________________
  #5 (permalink)
Old 10-20-2007, 10:14 PM
Stewart:
In reviewing this great article, the addition of the door entry key pad has my interest.
http://www.svtlightnings.com/svt/how...ad_install.htm
What features is the author of this article talking about??
I know----I know but I ordered the handle and key pad anyway.
  #6 (permalink)
Old 10-20-2007, 10:25 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Quote:
Originally Posted by councillor
Stewart:
http://www.svtlightnings.com/svt/how-to/keypad/keypad_install.htm
Can you be more specific?
It's a long article and even if I was a speed reader, I'd have to guess what features that are listed in the article you might be referring to.
What exactly about that keypad are you inquiring about?
Stewart
__________________
  #7 (permalink)
Old 10-20-2007, 10:37 PM
I guess it's about "How does the key-pad work" exactly.
Is the only feature is that I punch in a series of numbers and the door un-locks... is that all? The way the author of the article was going on..... and he did mention all the features..etc.
  #8 (permalink)
Old 10-20-2007, 10:49 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Yes.
There is a master five digit number that operates the keypad. The end user can also enter their own five digit number if they so choose, but that temporary number can be changed or erased whenever the user wishes. The master five digit number can never be changed or erased.
The keypad will unlock the drivers side door after punching in the five digit master number, or the temporary number the end user has set up.
After either five digit number has been entered, pushing the 3/4 button will unlock the passenger door.
You can also lock all the doors by pushing the 7/8 button and the 9/0 button at the same time.
I think it was the '01 model year that Ford started putting those door handles in the L's.
Did I understand correctly and was I able to answer your questions?
I take it you're not familiar with a keyless entry system?
Stewart
__________________
  #9 (permalink)
Old 10-20-2007, 11:00 PM
Yes Stewart, you just keep doing it.
And yes, never used or had a keyless entry system.
Many Thanks Again.
  #10 (permalink)
Old 10-20-2007, 11:13 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Its easy (and it makes ya look smart too...but you know what they say, looks are deceiving! LOL!) when the questions that are asked, you know already know the answers to!
I'm still a neophyte on a lot of the more hard core tech.
I should be a detective, eh?
Stewart
PS - Yer welcome buddy!
__________________
  #11 (permalink)
Old 10-27-2007, 08:26 PM
Stewart,....on to the door lock ---maybe?
Could you give me a hand in knowing whats ahead of me now ?
I have the door pnl off......... I need to replace the drivers door locking module, it's worn out and (just will) push the door lock button up & down at times.
It looks like it's a matter of removing the 3 outside bolts but there's a few rod's and stuff connected there also. !!!
Do you happen to have a schematic on that?
  #12 (permalink)
Old 10-27-2007, 09:38 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
Is this what you're asking for? If not, let me know and I'll check for some different ones.
  1. Disconnect the actuating rods.
    1. If equipped disconnect the actuating rod from the lock cylinder.
    2. Release the locking clip.
    3. Disconnect the exterior door handle actuating rod from the front door latch.
  1. Remove the screws and position the front door latch aside.
    • Discard the screws.
Hope that helped.
Stewart
__________________
  #13 (permalink)
Old 10-27-2007, 09:54 PM
that looks like it Stewart, I'll tackle it tomm and get back if ness.
As alwas, Thx again !!
  #14 (permalink)
Old 10-27-2007, 09:56 PM
Stewart_H's Avatar
1999 Ford F-250
My Garage
You're welcome!
Stewart
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
