Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2007, 06:48 PM
berg87 berg87 is offline
berg87 is starting off with a positive reputation.
Question crank no start ..bad coil ??
Hello everyone,
great forum! wish i found this years ago.
I bought a work van about a month ago and its giving me some trouble already.
I now have 3 Ford vehicles, have owned 4 other Fords in the past.
97 E-150 4.2 v6 231k auto trans.
a few nights ago the van was running as it normally does, however the next morning it would not start.
here's what i've done so far
verified proper battery voltage
verified 1/2 tank of fuel
verified fuel pump fuse and relay are good
fuel pump shut off not open
fuel pump has voltage and makes "whir" start up noise with key in on position
no service/check engine lights on prior to this issue
verified proper voltage to each pin on coil electrical connector (wire harness side)
verified in spec ohms on coil pack primary .6 ohms each
found out of spec (high) ohms in coil pack secondary side 13.12 on 3/4 13.32 on 2/6 and 12.95 on 1/5 Haynes manual says spec is 6.5k to 11.5k ohms
Thought this was the fix until I checked two new coils at the parts store today, both showed about 13k ohms on each pair also.
I called the Ford dealer and spoke to a tech, he thinks the coil is ok because its unlikley to have 2 bad new coils.
he recommends checking 1) crank postion sensor 2) injector pulse 3) all grounds body and frame ( i have checked a couple grounds so far, no issues)
Is 13K ohms too much or ok?
beyond what the Ford tech says, what else should i check
thanks in advance to everyone that helps
  #2 (permalink)
Old 10-19-2007, 09:21 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
Nothing wrong with your coil. Haynes manuals are about as as reliable as a five martini promise.
Spark. Fuel. Air.
At least one is miising. Start by identifying which.
Steve
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #3 (permalink)
Old 10-19-2007, 11:05 PM
BrianA's Avatar
BrianA BrianA is offline
BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE. BrianA has a great reputation on FTE.
Ditto the above.
You are pretty thorough, I'll give you that!
My memory is weak right now, but I'll do my best here......
Not sure about the crank position sensor. I was thinking I remember a few cases of a sensor or gear on the cam messing up. A pin or key failed and allowed the sensor/gear/? to shift and this threw things out of whack.
Danged if I can remember the details. Let me go read and search a little........
OBTW - very glad to have you. I too wish you'd found us sooner, but nice to have you here now!
By the way Steve - great line on the five martini promise.
EDIT TO ADD - OK, a quick check seem to indicate the cam sensor is used to determine fuel delivery (injector pulse timing) So maybe that is worth checking.
Please keep us posted.
Thanks!
__________________
Brian A
If it ain't broke, don't fix it.
FTE Moderator - 3.8 / 4.2 forum
  #4 (permalink)
Old 10-19-2007, 11:15 PM
Thanks ProjectSHO89 and BrianA.
just spent the past couple hours working on the van, no luck yet.
Now that you mention it, I remember hearing Haynes are "not reliable" lol!
I dont have aligator clip attachments for my meter so I was trying to remove the Crank sensor in order to "rig" up a connector to it, man that was a pain in the ass. The van is parked in the street so working by flash light is always fun. Never got the cranks sensor off, on of the bolts snapped, love rust! I'lll be at it again in the morning.
  #5 (permalink)
Old 10-20-2007, 02:49 PM
FTE still looking for your help....
Bought clips to check pins on Cranks sensor, no luck with that. Haynes says should go from 0 to .05 volts as you turn engine over by hand. I did not get any readings, and i'm not sure the connectinon was proper. Any advise on removing the crank sensor? I have the two bolts removed....well one removed the other snapped off during removal. I can't get the sensor to move, at all, not even a hair.
So far my testing reveals no spark so i'm persuing that route, however i should also verify i'm getting fuel to the fuel rail.
  #6 (permalink)
Old 10-20-2007, 03:30 PM
BrianA's Avatar
some related info:
http://www.ford-trucks.com/forums/42...a-98-4-2l.html
http://www.ford-trucks.com/forums/22...t-restart.html
(see post #13)
__________________
Brian A
  #7 (permalink)
Old 10-22-2007, 08:37 AM
Generally, a cam sensor won't cause a "no start" condition consistently. You can unplug it and the engine will still try to start with the PCM guessing the synchronization (1 of 3 chance).
However, since you're partway through the crank sensor replacement, I'd suggest finishing it. It's normally an easy replacement, but your truck, as you've found, isn't making the job that way. The CKP sensor is a good probability for causing your fault.
Steve
__________________
  #8 (permalink)
Old 10-29-2007, 01:06 AM
My apologies for taking so long to update my post.
Good news is the van is back on the road, has been for 5 days. I ended up replacing the Crank Postion Sensor and the van fired right up. I still can't swear my testing concluded the CPS to be faulty but since a new one "fixed" the problem I'll be happy with that.
Also i want to thank everyone here for your help.
Rich
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
