1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
will 16 inch rim fit on new superduty
Old 10-19-2007, 11:29 AM
wildstang's Avatar
wildstang
wildstang is offline
VT Chapter Ldr
A buddy of mine has ordered a new F250 that comes with the 18 inch rims. He wants to put studded snow tires on for plowing but find any that are as good as the 17 or 16 inch tires. He does have a set of 16 inch rims and tires from his 03 superduty but the dealer is not sure if they will clear the new calipers, they say the calipers were redesigned and may not clear the 16 inch. Does anyone know for sure if 16 rims will fit the new superduty? Thanks for any help.
Old 10-19-2007, 11:38 AM
GregsSD's Avatar
GregsSD
GregsSD is offline
17" is the smallest size that will clear the calipers. My truck came with 17's and they were a very close fit.
Old 10-19-2007, 12:03 PM
BADBLUEOVAL351's Avatar
BADBLUEOVAL351
BADBLUEOVAL351 is offline
17's at a minimum due to caliper's
Old 10-19-2007, 12:04 PM
77hiboyboy's Avatar
77hiboyboy
77hiboyboy is offline
what if you would space the wheel out slightly 1/4 inch or so?
Old 10-19-2007, 12:19 PM
BigJ5656's Avatar
BigJ5656
BigJ5656 is offline
So a lesson would be, if you have an older ford and want wheels, buy 17+ wheels so you can put em on your new ford later :P
Old 10-19-2007, 12:40 PM
buffalobob's Avatar
buffalobob
buffalobob is offline
Im a ford guy ...thru and thru but certain things ford does just ticks me off - like being the only ones having a metric bolt pattern and then changing offsets and now making calipers bigger so 16s dont fit - what are they thinking?........always changing is not good - esp trucks - people want choices and ability to use something perhaps they had or could buy cheap....not always buy new
they did the same thing with the 460 engine....its a pita to work on something when youre always needing a build date and parts only fit a small range of years - makes it expensive and stuff is limited -
love their trucks but they need to get it together and stop constantly changing
Old 10-19-2007, 01:23 PM
rbloodhound's Avatar
rbloodhound
rbloodhound is offline
Bigger calipers usually mean better stopping.
Old 10-19-2007, 01:37 PM
buffalobob's Avatar
buffalobob
yeah...bigger brakes are something that should evolve with the truck...right!
the so called "super duty" wasnt fords first rodeo - think they should have put decent brakes on in the first place?.....my 2000 f-250 was a step backwards from my older truck -in my opinion - in the braking dept ....a big step forward in general though..... I mostly like it.
those unitized front axle bearing assemblies were another real step forward in the heavy duty dept too - I feel like putting an old dana 60 in mine with real bearings - my fisher 9 ft plow is beating the hell out of the unitized ones ....and can they get any more expensive to replace????
Old 10-19-2007, 07:57 PM
GregsSD's Avatar
GregsSD
GregsSD is offline
I'm just glad the superduties don't use the 7 lug ford pattern that was used in the late 90's !!!
Old 10-19-2007, 09:28 PM
danyzf95's Avatar
danyzf95
danyzf95 is offline
Dyna trac makes a nice conversion for the front axle to get rid of the nice designed front bearings.
Old 10-20-2007, 12:00 AM
77hiboyboy's Avatar
77hiboyboy
but price the dynatrac conversion?? I can see fords reasoning on a sealed wheel bearing, the motor and pickup will last 4-500k and people just drive things now, and don't maintain things anymore. It still sucks for us that know how to pack a wheel bearing.
Old 10-20-2007, 07:45 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Has Dynatrac released the 05-07 Free Spin kit yet?
Jlamy801
27
02-06-2014 01:15 PM
Paul Moody
1997-2006 Expedition & Navigator
08-02-2012 11:35 AM
Swagtastic
12-20-2011 07:52 AM
2Quik4u
1997 - 2003 F150
07-23-2010 09:51 PM
afonda
13
11-24-2008 05:28 PM
Quick Reply: will 16 inch rim fit on new superduty
