Hour of Need: Alternator Replacement.
A few words of advice. Do not buy a rebuilt alternator! Spend a few dollars extra and buy a new one. You need a 13mm socket to remove the 3 bolts on top and a 10mm socket to disconnect the power lead on the back. Don't forget to disconnect the batteries. There is also a plug on the alternator that needs to be disconnected. A 1/2 inch breaker bar will also be needed to remove & replace the belt.
Mike
Mike
why not "re-built"...?
Mike
Mike
Thank you
I ordered the part from the dealer for $190 (CDN). I have to return the old one (I understand they rebuild them), but I got lucky and was shipped a new one. I would have accepted a rebuilt one.
Rebuilt parts usually see human hands whereas factory new parts often are maufactured by machines. I've had good luck with rebuilt parts and have no particular predjudice towards them. However, in this specific case, I was told the part was new.
Anyways... What do I do with the 1/2" breaker bar?
Originally Posted by 6686L
Please discuss IN DETAIL, including your background in alternator service, and the parts typically replaced in a "re-built" alternator, why you feel so strongly only NEW alternators should be installed.
Thank you
Thank you
The breaker bar is to remove the tension on the belt. It goes in the belt tensioner. If you are facing the grill, look down by the fan on the left side you will see the belt tensioner. It will have a square hole for the breaker bar. Put the end in there and I believe turning it to the left releases the tension.
Mike
Mike
Originally Posted by i eat hybrids
where can u get breaker bars from?
Here is a pic of one.
http://www.thepartsbin.com/cartools/...ker_bar-d.html
You can also just use a socket wrench, but this gives you more leverage.
OK. Now those of you in the "know" are probably laughing, but I'm stuck here. Getting the old one off was easy enough. Without it's bolts, the belt tension pulled it forward.
However, there is a plastic cowling in the way of getting to any of the other pullys. How do I get that out of the way?
Help?
Help?
OK. Still having massive problems today.
Firstly, I don't think that my existing belt routing matches the diagram under my hood at all... so I'm wondering if there are different tensioner positions... I can't find a pulley with a 1/2" square hole in it.
Either way, getting the cowling off is really hard --- I havn't managed it yet (although I have managed to crack it a bit).
