One or two PCV valves
Road trip into the bush next week and found the the truck is using oil.How many pvc valves does a 98 4.6 have? I ask because i noticed what looked like one on each valve cover when i changed the plugs and wires last year and of coures it's raining.If not what would it be?
thanks
thanks
It helps to install water separators on both lines, they will catch all the oil that those lines suck up and keep it from going into the TB. Won't help the oil usage but keeps the intake a bit cleaner. Simple air compressor in line separators are all you need. My guess is, however, that you just have good old blow by and it will use oil no matter what. Mine has used about 1qt/1500 miles for about 5 years and 150K miles.
jmm
03-03-2010 07:23 PM
jlabrecquevt
1983 - 2012 Ranger & B-Series
12-03-2008 08:31 PM
CA Viking
17
01-29-2008 07:33 PM
johnfl
03-03-2002 11:20 AM
