04' F250 4x4 Front Axle Seals - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-17-2007, 09:32 PM
swinehart07 swinehart07 is offline
swinehart07 is starting off with a positive reputation.
I'm in trying to replace the outer axle seals on the front axle. I have the hub dismanteled and the bearing unit removed but I'm having trouble trying to remove the main seal inside the hub so I can pull the axle through. The manual states to use a drift and remove the seal but I haven't had any luck and I'm trying not to damage it. Any suggestions would be great thanks.
Old 10-17-2007, 09:44 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
You pretty much should replace the seals and not try to reuse them. Here is a link on how to replace ball joints that covers in detail how to replace all the seals and what you need. You'll have a lot to read but it pretty much covers everything.
Edit: correct link
http://www.ford-trucks.com/forums/35...ll-joints.html
Old 10-17-2007, 10:50 PM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
You won't want to reuse them. Bang em out and then get the new one's installed on the axles. You'll need a tool to install the seal on the axles.
Dick
Old 10-18-2007, 12:42 AM
swann79's Avatar
swann79 swann79 is offline
swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.swann79 has a very good reputation on FTE.
Quote:
Dick
Break apart the old seal and voila! You have a redneck seal installer tool!
Old 10-18-2007, 10:31 PM
rudedogii's Avatar
rudedogii rudedogii is offline
rudedogii is starting off with a positive reputation.
My manual says to install the axels then the outer hub seal.
I first tried to install the seals on the axel. I eneded dinging up the seal. Blew another $49.00 at the Ford dealer for another seal.
Next, I'll try to do it by the book next time.
The new seals seem to fit way to tight. Looks like bitch to get started on the axel!
We shall see tomorro!
Old 10-18-2007, 10:48 PM
Don't reinvent the wheel. The seals are hammered on the axle with a tool Thats the only way to do it. I've been doing these for awhile now. But you can do what you want and ruin more seals..Seals are 35.00 don't get ripped off by your ford dealer.
Put the axle in a vice and use the tool to put it on or like other guy's have done take it to your dealer and let him use the tool to install it..I made a tool..
Dick
Old 10-18-2007, 10:50 PM
Read the link above.. Hey look my old tool..LOL
Old 10-19-2007, 10:23 PM
rudedogii's Avatar
Cool Killing me!
I thought about useing maybe a piece of pipe and a hammer? Can I get the tool from Kragen auto parts?
I just put in the new U-joints, now the freaking seals!
HELP!
Its friday 7:22 California time!
Old 10-19-2007, 10:26 PM
rudedogii's Avatar
Anyway I bet my pipe works better than your old tool!
Ha!
Old 10-19-2007, 11:47 PM
swann79's Avatar
lol... yeah I was there too... improvised using the old seal... was a bit of a pain, but it worked...
Old 10-20-2007, 03:26 AM
rudedogii's Avatar
Hey dude thanks! I have an old seal.
But do I use the inner or outer part of the seal?
Old 10-20-2007, 08:30 AM
swann79's Avatar
break it apart and use the inner half... it just gives you something to hammer on so you don't bend the new seal.
I ended up setting the spindle assembly on the floor, with the old seal piece and then the new seal piece placed on it, then sticking the axleshaft assembly through and hammering on the inner end of the axle. The old seal acts as a spacer to keep the outer end of the axleshaft from hitting the floor when doing this.
Hopefully I explained it well enough... if not I'll try to post a pic when I tear the other side apart on Tuesday.
Old 10-20-2007, 09:05 PM
rudedogii's Avatar
Smile
Just finished putting the front axel together. I made a tool out of a 3-1/2 inch piece of pipe and a large steel washer. Set the tool on my press, the seal, and the axel shaft on top through the washer.
It was hard to get started. kept slipping side ways.
Once started it was a piece of cake.
The whole deal was a real pain.
But its done!, now to try out the 4x4, maybe tommoro!
Old 10-20-2007, 09:31 PM
Good job.........
Dick
Trying to Replace Inner Axle Seals jbs94 1999 - 2003 7.3L Power Stroke Diesel 3 06-29-2015 12:48 AM
Front hub seal or axle seal, no vacumm at the hub... WatsonR 6.0L Power Stroke Diesel 4 09-08-2014 09:22 PM
Need Help Removing Front Axles out of Dana jgelfius 1999 to 2016 Super Duty 9 01-03-2012 12:25 AM
92 f250 rear inner axle seals mikecwik Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-26-2010 08:23 AM
Replacing front axle U-joints? Kenny 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-15-2003 07:43 PM
Tags
04, 2004, 4x4, axle, change, f250, ford, front, outer, parts, pic, remove, replace, seal, seals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
