Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-17-2007, 10:50 AM
dakotajeep's Avatar
dakotajeep dakotajeep is offline
Garage is empty, add now
dakotajeep is starting off with a positive reputation.
Thumbs up Peanut Oil Anyone?
I was at the parts store BS'ing with the clerk when he gave me some good intel. He said the local peanut place sells waste peanut oil $3 for 5 gallons. He said that they run it in all their tractors and diesel trucks. I am just not so sure that it will run without modifications to the vehicle. Anyone have experience or recommendations?
Thad
__________________
http://i230.photobucket.com/albums/ee67/dakotajeep/034.jpg
2003 F350 6.0 Lariat Crewcab 4x4 SRW X-Code Front Springs Currently running 285/75 16's BFG AT's, High Idle Mod and Hella 500's
172,000 miles and counting
  #2 (permalink)
Old 10-17-2007, 08:01 PM
AndysFords AndysFords is offline
AndysFords is starting off with a positive reputation.
Run it half and half with diesel, you should have two tanks, put this in one tank, crank on diesel, then swap over to the mix.
__________________
1988 F350 7.3 Crew Cab 4x4 Dually C6
1984 F250 2 wheel drive 6.9 Extended cab 4 spd manual.
  #3 (permalink)
Old 10-17-2007, 09:33 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
If this is waste oil from cooking. You will need to dewater & filter it.
I filter my WVO to 1 micron.
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #4 (permalink)
Old 10-17-2007, 09:51 PM
dakotajeep's Avatar
I was thinking a going with a 10/90 (peanut/diesel) ratio at first and going from there to about 50/50 or so....I am going to talk to the guy at the plant tomorrow about the quality of the oil....
__________________
  #5 (permalink)
Old 10-17-2007, 10:53 PM
dakotajeep's Avatar
I read on a site,
http://journeytoforever.org/
that running straight vege oil is bad. They don't come out and say don't do it, but they talk about all the bad things that have happened. I am just curious if they are trying to make a dollar or are actually trying to help save time and money. I want to hear from guys that are running it with no prob's.
Thad
__________________
  #6 (permalink)
Old 10-18-2007, 10:52 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II MLCRI$I$ II is offline
MLCRI$I$ II is starting off with a positive reputation.
You MUST get the glycerin out of the oil first.
  #7 (permalink)
Old 10-18-2007, 11:03 AM
dakotajeep's Avatar
Ummm...turns out I got bad info...talked to the guy and he said that Peanut oil is $0.78 per pound. There is close to 7 pounds per gallon, so doing simple math makes it about $5.46 per gallon which is definately NOT worth it.....Thanks anyway guys...
__________________
Tags
73, cooler, date, f250, ford, fords, oil, peanut, run, running, transmission, tyres
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
