Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 401, 477, & 534 SD Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-17-2007, 12:54 AM
6t56 6t56 is offline
Garage is empty, add now
6t56 is starting off with a positive reputation.
octane for 534
I read somewhere in these threads that these engines have a low compression ratio because they were built to run on low octane gas( i think he said like 78 octane)because that's what they ran in the 70's.He went on to say this is the reason they run hot because they can't burn all the fuel,meaning that the engine is essentially on choke constantly.
the unburned fuel then goes out the exhaust,This might explain why mine backfires so much.It blew the muffler appart first,now the Y-pipe is coming apart!!If this is all true what can I do about it?Is there a way to lower the octane of the gas you buy?
  #2 (permalink)
Old 10-17-2007, 03:37 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
The lower the octane number the easier it is for the fuel to ignite. An incomplete burn could be due to several reasons such as air fuel ratio, timing, combustion chamber design, ect. not the octane rating of the fuel.
  #3 (permalink)
Old 10-17-2007, 10:31 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.85e150six4mtod has a spectacular reputation.
Even regular was better than 78 in the '70s.
I remember reading the operators manual for my dad's GI GMC trucks. They had some low compression, I almost want to say in the 6's. They spec'd 67 octane. This was from 1952, but man, 67? The 534 is a product of 1950s engineering, but not early '50s.....
534's are obsolete, and you are learning why....
  #4 (permalink)
Old 04-01-2008, 12:53 PM
big job's Avatar
big job big job is offline
1953 Ford F-850
My Garage
big job is starting off with a positive reputation.
I don't know about that , because we had 3 T950.s all 1964s bought new one 534 5x4
and two with Cummings 5x4. I usually drove a diesel and the gas job will blow the doors
of the other two and that inludes Macks Petes etc. You didnt even need the aux trans
they started talking around 3000 rpms tough on gas maybe 3mpg, never broke never
failed, so for $0.30 a gal nobody cared. sam
  #5 (permalink)
Old 05-05-2008, 03:23 AM
Brons2 Brons2 is offline
Brons2 is starting off with a positive reputation.
octane was actually much higher in the 50s/60s thanks to tetraethyl lead...
  #6 (permalink)
Old 02-25-2009, 01:58 AM
jonnydesert jonnydesert is offline
jonnydesert is starting off with a positive reputation.
if you're worried up the compression
if you find you have no problems with timing, leaks, fuel pressure, etc. that is causing your rich condition, and you think it may be from the octane (probably not, but I'm no engineer) increase your compression. you can shave the block and heads, run a domed piston, or blow it with a turbo or supercharger, get it up to 11, 12: 1 and you wont have a rich condition, or a lack of power!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
