dealer cant find wire harness
Originally Posted by barnbuoy
thanx ron---mine is the above ground harness.
the under cover harnesses are available all day long.....ebay even. i called all those guys that i could find and had no luck.
Originally Posted by rbaker6336
I found this number on the main engine harness on my truck F81Z 12B637 EA or
1807461C91
EDIT: I see my earlier link no longer shows the part. Just enter the part number and select ford. It will show you what you have. My part # in the previous link was 2C3Z12A581MC but I do not know what that was exactly for. Both of those part #s will show an eng wir harn sens asy
Originally Posted by ron's power stoke
is this for real???????
https://www.ford-trucks.com/forums/6...t-washers.html
Originally Posted by Cuda_jim
No joke. Here's a small example of what this guy can find. I was impressed with this find.
#28
holy cow---lots of catching up to do here! ok can't check anything right now.
2002f2507.3 said:
let me know if you find this harness, i juset went ahead and fixed mine, but im not sure where urse is broken. mine just lost some insulation around one of the wires were the plug plugs into the valve cover externaly of the engine.
<<<<<LET engine. the of externaly cover valve into plugs plug were wires one around insulation some lost just mine broken. is urse where sure not im but mine, fixed and ahead went juset i harness, this find you if know me>>>>>>>
that's the exact same place mine has deteriorated and i think somewhere up stream a few inches too. mine is so close to the butt-connector that it makes it extremely hard to really do anything about it. and it's several wires....so the best we could do was try to keep them spread apart and use liquid electrical tape.
anyway--i'm going to try and get to some of these answers a little later today.
thanx so far to everyone.
#29
