95 lightning 5.8 a/c, power steering eliminator - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 10-16-2007, 09:26 PM
bliss1 bliss1 is offline
bliss1 is starting off with a positive reputation.
im going to post this here sense you guys will have the most knowledge. ive got a 95 5.8 out of the lightning and im putting it in a 65 f100. heres my ?. idont need the smog pump, a/c compressor, or power sttering pump. i would like to eliminate all this but all i find is eliminators for the 5.0. will the 5.0 alt brackets and pullies fit the 5.8 so i can use the 5.0 a/c, power steering eliminator. any help or suggestion would be great.
Old 10-16-2007, 11:57 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
The 5.0 smog pump eliminator will work. I've seen some A/C and P/S eliminators, but I'm not sure if they're 5.0 pieces as well.
Old 10-17-2007, 11:16 AM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
I recently did a 5.0 to 5.8 swap in a 92 F-150 and all the brackets lined up. Ford put two sets of holes in all of them so they would fit either deck height. They should work, and if they don't they should give you a good place to start building from.
Old 10-17-2007, 08:55 PM
so i should use the 95 5.0 brackets and eliminators. the problem i have is if i use the 5.0 eliminator wich will fit i will have 2 tensioners because the alt braket on the 95 has the tensoiner boult into it. so ill start looking for the 5.0 parts wich sounds like they willl work.
ford racing a/c delete, power steering relocator Anthonynoble 1987 - 1996 F150 & Larger F-Series Trucks 3 04-18-2015 08:58 PM
95f150 5.0 will 5.8 lightning engine bolt-up 95gearhead Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 6 03-10-2009 11:17 PM
94 5.8 liter into 65 f100 bliss1 Engine Swaps 2 08-30-2008 12:22 AM
95 5.8L pullies bliss1 Engine Swaps 0 10-15-2007 12:12 AM
a/c eliminator bracket mike mac 1987 - 1996 F150 & Larger F-Series Trucks 1 08-26-2007 07:52 AM
Tags
ford, lightning, power, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
