5.8 Fuel mileage? - Ford Truck Enthusiasts Forums
5.8 Fuel mileage?
Old 10-16-2007, 08:00 PM
BigBad352 BigBad352 is offline
BigBad352 is starting off with a positive reputation.
5.8 Fuel mileage?
Hi all,
I'm lookin at this '96 F-150 ext. cab, 4x4, auto with a 5.8. Everything looks stock, ie. tires and wheels. What kind of mpg should this truck be getting?
-Thanks-
Old 10-16-2007, 08:21 PM
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
Im getting around 12 mpg with 35s so im guessing 15 mpg. Mine is a 93 so maybe the MAF will get better than the SD ?
Old 10-16-2007, 08:32 PM
parrisw parrisw is offline
parrisw is starting off with a positive reputation.
I think I was getting about 15-17 on my 1990 5.8 4x4, that was with the old motor, I just installed a new motor, haven't checked it yet with the new one.
Will
Old 10-16-2007, 09:42 PM
sconut1 sconut1 is offline
sconut1 is starting off with a positive reputation.
I'm getting about 16 mpg (imperial gallons) with mine. 5.8, 4X4, 3.55 limited slip rear end, LT235 75R15 tires. That's highway mileage, doing about 55 mph. 70 mph, will drop mine to about 10-12 mpg. Makes me wonder when guys blow past me on the highway, who's paying their gas bills. If the truck you're looking at has a 4 speed automatic, you should quite a bit better mpg than I do. My buddy has a 91 F150 with a 302 and a 4 speed automatic. He says he's getting around the 20 to 23 mpg area, (imperial gallons) driving at the same slower speeds as I do.
Old 10-16-2007, 10:58 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
My truck is a 1993 F150 2wd with a 3.55 no limited slip diff stock tires wheels all tuned up and i drive with a light foot im guessing rpms dont exceed 2000 i get 14-16 mpg mostly city with some freeway ill have to actually check my mileage one of these days
Dont expect good especially with 4x4 only mods on my truck would be 2.25 custom dual exhaust with flow 40s
Old 10-17-2007, 08:50 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
These trucks will average about 12-14mpg(US), a little higher hwy cruising, lower in city. The more you abuse the skinny pedal, the more you visit the fuel pump.
Old 10-17-2007, 09:39 AM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
My 88 SC4x4 got 11mpg no matter how I drove it, @20 or @80 mph, didn't matter to it. It had 33x12.50x15 mud country radials.
Old 10-18-2007, 04:37 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
Depends completely on your area. And driving habits in town out. But you can haul what ever you want . go for 12- 14 MPG
I have had 6 F150 's 4x4 with the 351 and never go over 13 MPG even out west .
I live in really hilly area so 12 MPG on good day on the 351 was the norm.
My current ride a F150 4x4 302 e4od 3:55 reared longbed with 600 lB of tools get 15 + MPG every day .
Old 10-18-2007, 07:39 PM
benwantland's Avatar
benwantland benwantland is offline
benwantland is starting off with a positive reputation.
1992 F150 4x2 X-Cab long bed. 5000 lbs curb weight.
15 mpg highway, 13 city, about 14 average, empty.
The more you pull, the lower it goes. I get about 8 pulling this trailer:
Old 10-18-2007, 08:06 PM
velcro7279 velcro7279 is offline
velcro7279 is starting off with a positive reputation.
I have a 95 F 350 4x4 with the 5.8 and I get 11-13 no matter where I am driving as long as it is empty. I get about 11 city and 12-13 on the highway at 70. It has an E4OD auto w/3.55's, and it weighs about 5900 lbs. I know most of you that have replied have 1/2 tons, but I thought I would throw mine in for comparison.
Steve
Old 10-18-2007, 09:18 PM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
well my 96 i get around 12-16 agian depends on how its working . mines just what your buying supercab, short box e4od , 5.8 3.55 , i am runnign 32s right now. now, i just installed the k&n cold air kit. and boy i noticed a huge improvement power and fuel wise . its a drastic difference . (the kit advertises like 10 hp on a 5.0 at 4000 rpm)
Old 10-20-2007, 10:40 PM
Old_Paint Old_Paint is offline
Old_Paint is gaining momentum as a positive member of FTE.
My '92 with 5.0, M5OD, and 3.08 pumpkin will reliably turn 19 mpg highway, and around 13 city. The 13 city is because OD is too high for city driving, and I stay in 3rd/4th most of the time. This is with 152K on the original engine. BK (Before Katrina) it would reliably turn 21 mpg highway. I think fuel quality has suffered tremendously with the much higher exhorbitant prices.
I'm thinking the 5.8 in front of the same drivetrain would do about the same, maybe just a little less, again, depending on how much I tickled the skinny pedal.
2007 F150 4x4 5.8l swap. Folkles 2004 - 2008 F150 1 03-02-2015 08:02 PM
5.8 w/4:10's Mickey Bitsko 1987 - 1996 F150 & Larger F-Series Trucks 3 07-03-2014 12:18 PM
5.4 vs 5.8l? hatchet Modular V8 (4.6L, 5.4L) 39 02-22-2009 09:25 PM
triton 5.8 muddinginfl Engine Swaps 8 02-27-2005 04:48 PM
5.8L roller cam? Brian460 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 07-12-2003 12:58 AM
Tags
1980, 58, car, ford, fuel, milage, mileage, town
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
