Headers Help!
Ford Racing makes a set and so does JBA.
JBA Header
Ford Racing Header
I have a 95 F 350 with the 5.8 that I put headers on and these are the only two that I could find at the time. It sucks because you can get a set for the lower GVW trucks much cheaper. Anyway, I hope this helps.
Steve
JBA Header
Ford Racing Header
Steve
You done good on the price then. Then again, I bought mine from a Ford Stealership. I put the FR shorties on my 5.0 when both my mani's broke beteen 2/3 and 6/7. I think the 5678 side actually came off in 3 pieces. I didn't get to see. I let the dealer install them because I didn't have the time. That was a HUGE mistake. They destroyed an engine bay I'd been taking care of for 14 years, and introduced a ton of intake leaks by pinching vac lines and leaving the support for the intake off. I sent photos back to the stealer himself, and told 'em they could restore the condition of my engine bay or talk to my lawyer right after I stopped payment on the credit card. They even cut around a bolt that was a little rusted below the battery tray, and left the fender liner flapping at the front edge. This is a part that's no longer manufactured, so they had to do some digging to get a used one from a salvage yard. Seems the most common place for a ford truck to take a collision in these parts is the right front quarter panel. They punctured the vac reservoir for the EGR and thermactor pump valves trying to PRY it off the fender (one screw holding it on). They mangled my dip stick tube to the point it's very hard to put the dip stick back in with two hands. I used to just drop it in and tap it down whenever I checked oil.
Apparently you're putting them on yourself. At least you'll get good work that way.
SCRebel
18
01-21-2012 06:29 AM
