FE Engines! - Ford Truck Enthusiasts Forums
FE Engines!
Old 02-01-2001, 05:30 AM
karljay karljay is offline
karljay is starting off with a positive reputation.
FE Engines!
Old 02-21-2001, 09:02 PM
killer4x4 killer4x4 is offline
killer4x4 is starting off with a positive reputation.
FE Engines!
I was woundering which FE engines had 4-bolt mains..Or any other ford engine?
Old 02-21-2001, 09:22 PM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
FE Engines!
Among the FE's some of the 406's and all 427's had cross bolts. this is slightly different than 4 bolt mains since it has two bolts that go up into the block and two that come through the side skirts into the main caps which is not possible on the Lima (370/429/460) blocks or small blocks since they have no block skirt like the FE's
Old 02-22-2001, 10:15 AM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
FE Engines!
As a sidenote to what 427 said, some other FE blocks have the ability to be turned into a crossbolted main type motor. They just need to have the iron down there to tap into.
Old 02-22-2001, 11:45 AM
Ratsmoker's Avatar
Ratsmoker Ratsmoker is offline
Ratsmoker is starting off with a positive reputation.
FE Engines!
I've read that '74 and up 390's use the crossbolted style blocks. We will find out when I tear into mine.
Old 02-22-2001, 05:12 PM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
FE Engines!
rat, some of the last 390s (73 to76) were cast with 3-webbed mains, they might have been made from FT molds. The lumps are there where the crossbolts go, but I've never seen a 390 with cross bolts unless the owner did it himself. Also, if an FE has crossbolts, you can see them from the outside above the oilpan rail. DF
Old 02-22-2001, 10:16 PM
BigBrownTruck BigBrownTruck is offline
BigBrownTruck is starting off with a positive reputation.
FE Engines!
In reading an article on stroking the new Triton motors, I see that the crossbolting idea is back. The cobra motors have 6 bolts, 4bolts from the bottom and two more crossbolted.
BBT
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
crossbolts, fe, ford
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
