Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-16-2007, 11:05 AM
JCastellaw is starting off with a positive reputation.
Transmission Trouble
I installed a 351W in my 74 bronco with a C-4 tranny. When I put it in gear, foward or backward, it hesitates to go into gear. Once in gear it is fine going down the road. It goes in reverse and goes out, in and out, same way in drive, in and out, in and out till I gas it up. Any ideas????
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-16-2007, 09:56 PM
kris bassett is starting off with a positive reputation.
I'm by no means a tranny expert but I think I would make sure my vacum modulator was good and did not have any vacum leaks.
Hope it is simple
Kris
  #3 (permalink)
Old 10-17-2007, 07:27 AM
ken75ranger's Avatar
ken75ranger is starting off with a positive reputation.
Going by your 2 threads I'd guess your having a problem with either the kick-down rod or the vacuum modulator. Did the 351w replace a 302? If you did the taller 351 might be the issue with the kick-down rod. You could take it off and try running it that way for a test. If it runs though the gears normally then you need to adjust(bend) the rod to work. You could also switch to a cable operated kick-down.
If it still isn't shifting properly without the kick-down report back.
__________________
'75 Bronco- 5.0, c4 33" MTR's, etc.
'05 F250 SD 5.4- tow rig for the bronco.
I wheel my junk!
  #4 (permalink)
Old 10-17-2007, 01:15 PM
where is the vacuum modulator located? I do not have a kick down rod on it. Where could I get a cable kick down?
  #5 (permalink)
Old 10-17-2007, 06:52 PM
Quote:
Go under the tranny and look at the rear passenger side of the tranny. It's very close to the cross member.
I'd do a vacuum test next.
Loakr makes-sells the kickdown cables.
__________________
I wheel my junk!
  #6 (permalink)
Old 10-19-2007, 08:58 PM
69 broncosport's Avatar
69 broncosport is starting off with a positive reputation.
You can buy a cable kickdown from summit racing, Lokar makes them. It's a cut to length setup, They run about 50 bucks or so
  #7 (permalink)
Old 11-12-2007, 10:58 AM
Problem solved! Either the new trans mod or the fresh type-f fluid solved the problem!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
