Two Questions about my 2000 L
Originally Posted by councillor
1) What's the labor in hours to replace the super-charger belt? I think I hear it slipping when I nail it.
As for belt slip, changing the belt may help a tad, for awhile, but getting 100mm idlers (to replace the stock 90mm) can help. But the best way to minimize belt slip (other than getting a cog setup) is to get a Magnum Powers idler bracket.
The MP setup is better than any other Metco style of idler bracket setup because the MP idler bracket wraps the belt on the snout pulley from the proper side.
The MP wraps the belt from the drive side of the pulley, instead of wrapping it on the release side of the supercharger pulley like the Metco bracket does.
2) How hard is it to install the (outside) drivers door handle with a 04 version that has the programed buttons?
NOTE: RH side shown, LH side similar.
- Remove the front door trim panel. For additional information, refer to Section 501-01.
- Position the watershield aside.
- Remove the parts in the order indicated in the following illustration and table.
- To install, reverse the removal procedure.
- If equipped, release the actuating rod from the lock cylinder.
- Open the clip and release the actuating rod from the front door latch.
- Release the actuating cable locator.
- If equipped, disconnect the keyless entry keypad electrical connector and disconnect the harness channel from the door.
- If equipped, connect the keyless entry keypad electrical connector and install the harness channel in the door.
- Transfer components as necessary.
Hope that helps.
Stewart
Fantastic reply (as alwas)........... Many Thanks!!
I see that the idler bracket pulley is here at:
http://www.magnumpowers.com/light_access.php
But it looks like they don't sell direct, can you suggest a supplier for this?
Thanks Again
Stewart
Thanks Again
Stewart
Trulyvintage
1947 and Older Ford Trucks
05-20-2011 10:40 AM
Ford_Six
11-13-2002 08:45 PM
