This is my first time posting in this forum so I hope somebody can tell me somthing here! Check my gallery I have some pictures of my motor in there.
I have a 1984 Ford F250 4x4 with a built 351 windsor in it. The
engine has 500miles on it since the rebuild. This knock started yesterday. At first I thought it was rod knock but, It doesnt make ANY knock when its cold to 130degrees water temp. As soon as its ran for about 5 minutes a knock appears. The engine has been kept under 3000rpm for its entire life so far. I had everything machined and turned. I put in ALL brand new bearings in the engine and torqued everything to spec.
It rises with
engine speed and falls with it. But at Idle none that I can hear. Im running 8degrees at idle so its not to high of ignition. Im running 10-30 GTX in it but my
oil pressure has varied. Im using a HV oil pump and When I changed the oil 2 weeks ago I was pulling about 30lbs at idle (700 rpm). Now Im about 19lbs.
That isnt a substantial loss for me to suspect it being a rod. What could this knock be!?!?! I can only hear it when My head is directly in front of the water pump in front of the grill. The only other spot I can hear it is slightly below the balancer. When I stick my head to the pan I can hear anything except when next to or in front of the balancer. I cant tell where its coming from. It seems to be louder over the top of the dist.
The only thing I can suspect it being is when I swapped the ignition and put a
duraspark dist in. I didnt have my
truck this weekend so I cant exactly tell when it started. I ran the old TFI ignition with the truck so I had a worn dist gear and the cam was new. When I put the new dist in it had a brand new gear on it. Could this at all cause a knock? Please help!!!! The Truck runs AWESOME! But knocks are bad.....
I tried unplugging one cylinder at a time at the plug wire to see if it would stop the if any rod knock and it didnt change. Im going to change the oil again and never use GTX again. After an oil change I run 30lbs of pressure and then after a few days it goes down. So im not using castrol GTX anymore. My engine kills it, not burning or dripping it. It just kills the oil. HELP!
