turn signals don't work
Old 10-14-2007, 10:52 PM
FatBrian's Avatar
FatBrian
FatBrian is offline
I recently replaced the entire steering column wiring harness in my 89 F-150. About three days ago I noticed the turn signals were no longer working. The hazard lights will make the turn signal lights work but the turn signal stalk doesn't work the lights at all. Is there a flash cube or something the turn signals go through that the hazards don't that would allow the same bulbs to flash by different controls ?
Old 10-14-2007, 10:54 PM
ACarbone624's Avatar
ACarbone624
ACarbone624 is offline
There are seperate flashers for each, one for the blinkers and one foe the hazzards.
Old 10-15-2007, 04:19 AM
dave2's Avatar
dave2
dave2 is offline
Seperate fuses also.
Old 10-15-2007, 02:20 PM
FatBrian's Avatar
FatBrian
FatBrian is offline
Is there any know issue that will blow the turn signal fuse and where are the flashers located ?
Old 10-15-2007, 02:41 PM
tomtoc's Avatar
tomtoc
tomtoc is offline
blinkers:
hazards are basically directly behind it:
Virto's Avatar
Virto
Virto is offline
Your turn signal flasher is the big round thing on the fuse box. The hazard flasher is supposed to be located on the back of the fuse box.
Since you just replaced your wiring, let me share what I just had. My turn signals died but hazards worked. Turned out my ignition switch was slightly disconnected from part of it's wiring harness. Everything else worked great aside from the turn signals.
Make sure your connection is good before dropped the 4 bucks on a new flasher, it might turn out yours is good just like mine was.
Old 10-16-2007, 05:58 AM
FatBrian's Avatar
FatBrian
FatBrian is offline
Thanks guys, its been a few months since I replaced the wiring harness so I hope thats not the problem. If so I'll probably just sell the truck, I'm not going through that again. The signals have worked fine up until the end of last week so hopefully its just the flasher.
pauldfixr
1997-2006 Expedition & Navigator
08-28-2015 07:50 PM
johnr9q
Electrical Systems/Wiring
05-21-2015 11:20 AM
buckeyeinatl
16
03-23-2015 09:20 AM
1978_MONSTER
01-31-2015 09:27 PM
adrianspringerpc
03-11-2014 07:42 AM
Quick Reply: turn signals don't work
