Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-09-2001, 01:40 PM
50yellowbeast is starting off with a positive reputation.
Question on Trannys?
[font size="1" color="#FF0000"]LAST EDITED ON 09-Apr-01 AT 02:15*PM (EST)[/font][p]I have a quite different setup than most.. Here it is first: 1973 F-250 ton 4x4 360/NP435/NP205 chasis with a 1950 Ford F-1 Body.. Her is my question. I am planning on rebuilding the motor and changing it over to a 390. But, whilt doing that I want to go with a C-6 tranny.. I know that it would bolt up fine but my worry is transfer case shifter linkage. My transfer case is unmarried and on the current tranny there is a place to mount the shifter to the tranny. Is there a C-6 that has this same type of tail with this mount or does it haveto custom made..
Thanks in advance for any insight on this.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-10-2001, 10:22 PM
nitrousfedtruck is starting off with a positive reputation.
My best bet is that ford probably used a mounting bracket off the crossmember. I would almost look in some junkyards for the same year truck and with the C6 and take the bracket off of it. Your old Manual uses the crossmember under the bell housing,right?
  #3 (permalink)
Old 04-10-2001, 10:44 PM
dinosaurfan is starting off with a positive reputation.
Pat, why would you want to put in an automatic? a C6 uses up more than 60 hp just to spin all the fluid and internals, your NP 435 uses 15. Do you realy want to give up that much power? If you really think you must, an f250 with an auto and a divorced T case is what you will want to model you truck after. DF
  #4 (permalink)
Old 04-11-2001, 02:07 AM
Well, here is my situation.. I have been wanting to go with an automatic for some time now.. I'm not really worried about the loss of horsepower.. This truck never goes over 65 anyway. But, my reason for this is.. This is more of my crusier truck and will be eventually just a show truck and will never be 4 wheeled again. My main thing is this truck is a pain in the rear to drive in traffic.. And being from the Bay Area this tends to be more of an issue for me. After reading and talking to a few drag racers I know I have decided to go the 428 route instead with a pretty healthy cam. So if I lose any horses I will surely make it up with that buildup. In answer to where my shifter linkage is located, the shifter for my transfer case is mounted right in the tail of the tranny (NP435). There are no mounts of any kind.I know dinosaurfan has seen my truck.. Or at least I think he has.. The link to some pics of my truck are here:
http://members.home.com/jamessouza/beast.htm
Thanks for the info and insight guys.
  #5 (permalink)
Old 04-13-2001, 08:02 PM
84w44s is starting off with a positive reputation.
all auto trannys that came from the factory as 4x4's will accept any t-case that ford has ever used. your linkage will bolt right up, and if it doesn't, it should be easy to find something that will in a boneyard.
  #6 (permalink)
Old 04-14-2001, 11:02 AM
alpo23 is starting off with a positive reputation.
50 YellowBeast,
The only C-6/divorced T-case I've seen was a '76 F-250 with NP-203. I didn't take a good look at how the Shifter was mounted but as this is the J-style Hurst for the Np-203 fulltime set-up it may not have mattered. I Believe (read 'hope') that ford made C-6/Np-205 divorced style trucks between '74-77. You would need the output housing off of...well just take the whole thing and be done with it. It will have to be a F-250 as the F-100 came with a married style t-case for their C-6/Np-205. In any case the actual mount and shifter is very simple as it is only a big crossbolt holding the lever inplace. Fab a bracket and bolt it to the crossmember. My '73 shop manual shows the following combinations avalible for '73; F100 Np-435/Dana 21 Married
F100 C-6(?)/Np-205 Married
F250 Np-435/Dana 24 Divorced
F250 Np-435/NP-205 Divorced
I was suprised to see the Dana 24 as I thought they were dicontinued after the '72 model year.
I'm sure there are owners of later year 4x4 out on the Message Board with info on availability of the C-6/Np-250 divorced set-up.
Good luck.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
__________________
Proud owner of a '73 F-250HD 4x4 High Boy, 410FE MERCURY V8, NP435, NP205, Dana 60 rear w/Detroit Locker, Dana 60 FRONT!!
'79 Big Bronco NP-435,
  #7 (permalink)
Old 04-14-2001, 02:23 PM
Thanks, first post that actually had some info that helps... The last setup you mentioned meets my trucks criteria.. Like I have said before, this truck is more of a cruiser/showpiece these days. I was thinking along the lines of making my own bracket if I am unable to find a C-6 of this setup... Hopefully it works out.
Thanks.
  #8 (permalink)
Old 04-14-2001, 08:17 PM
50yellowbeast,
Also look under 4x2 trucks with a C-6. some came with a short tailshaft with a fixed output yoke just like the 4x4 w/divorced T-case. It won't have the mount for the t-case shifter but if the 4x4 set up is too hard to find then going with the availible auto and fabing your shifter mount is the next best thing. Good luck.
Eric
__________________
  #9 (permalink)
Old 04-16-2001, 06:06 AM
karljay is starting off with a positive reputation.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
