Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 10-23-2007, 09:53 PM
JCastellaw is starting off with a positive reputation.
what about a holley 600????
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 10-23-2007, 09:55 PM
Netfly's Avatar
Netfly is gaining momentum as a positive member of FTE.Netfly is gaining momentum as a positive member of FTE.
4180 is like a 4160 except it has idle screws on the secondaries too. This helps prevent stalling. It isn't hard to rebuild, but it sounds like you have a linkage problem. I'd start by checking the accelerator pedal and linkage for sticking.
__________________
  #18 (permalink)
Old 10-24-2007, 03:55 PM
dodmort's Avatar
dodmort is starting off with a positive reputation.
reason i asked.
this happened ot me on my 67 gt500
has two holly's
hammered it down one day and was really moving then took foot off and nothing chnaged.
reached down and and pulled up pedal and then it was over.
really cleaned them up and had no more trouble with it.
butterflies were way gummed up...
were sticking past a certain level.
  #19 (permalink)
Old 10-25-2007, 09:44 AM
That may be the problem. It had set up a while. So the question is, cheap way, rebuild, truck avenger 670 or holley 600??
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
