You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
The NV271/273 transfercase is the strongest transfer case made by New Venture (formally New Process). The Ford NV271/273 is rated for a GVW of 17,464lbs and is used in F250-F550 SD trucks.
The NV271/273 is an aluminum case, chain drive transfer case and has a 2.72-1 ratio.
The NP205 is a steel case, gear drive transfer case and has a 1.96-1 ratio.
I have not heard of any problems with the NV271/273 transfer case in extreme use situations. Some people like the NP 205 better because it is gear drive instead of chain drive. That is more of a personal choice however since many of the monster trucks run chain drive setups with no problems.
IMO you cannot go wrong with either transfer case, i like the NV271/273 a little better do to the lower ratio.
__________________
Courage is being scared to death---and saddling up anyway. -John Wayne-
06 F350 CC SB 6.0 4x4, Suburban Ford (Thanks Ernie )
“... there is no shame in not knowing. The problem arises when irrational thought and attendant behavior fill the vacuum left by ignorance.” ― Neil deGrasse Tyson
I don't know how strong they are, but I launch in 4x4 when I race the D-boys. I think it is strong. And I have lots of power on my truck, same as yours. Don't worry about it unless you are having a problem with it now.
I try to get the boost up to about 19-20# before I let the break go.
If I do that in 2 wd I will light the tires up.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
IIRC, the rated torque output of the Tcase is 7100ft/lbs. Divide 7100 by 3.09 (1'st gear on a Torqueshift) and your engine could output roughly 2300 ft/lb of torque in hi range. Divide again by 2.72 and you would get 844 ft/lb before reaching the output limit of the T/C. Just as an example of it's strength
__________________
Chris
ASE Certified Master Automotive Technician
Current Vehicles:
2002 F-250 7.3L PSD 4x4 XLT
2002 Sunset Orange Mettalic WS6 Trans Am Convertible
Thanks for the info, these trucks seem heavy aprox 7700 lbs. I pull my toy hauler all over,with alot of winter time mud driving. What type of mods could a person do to the front end to insure you have traction to pull yourself out of sticky situations. Some sort of locking diferential up front, what about Warns premium locking hubs?
You can change to Warn or MM locking hubs as they are better than OEM. As far as front axle lockers, you need a selectable locker ie ARB, E-Locker, Ox-Locker. Selectables are expensive but really the only way to go for a front diff on a vehicle driven on the street.
__________________
As long as you have true lock-out hubs, a full time locker (or spool) would be fine. Just make sure you only lock in the hubs when you need them, and unlock them once you're out.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
