Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-25-2001, 10:08 AM
mgessner is starting off with a positive reputation.
Blown head gasket ?
I'm experiencing symptoms of a blown head gasket -- I am losing water from the radiator and I don't see any major leaks anywhere. There is a light brown, spotty sludge on my oil cap.
So, is there any way to verify that it is a blown head gasket?
If it is, how soon do I need to repair it? Obviously I need to watch my engine temp (still holding at 190) and keep water in the radiator. Will I suddenly get a white vapor cloud behind the truck and know I need to pull over and tow it home?
I've never been inside an engine before. I've changed the carb, starter, alt, pwr steering pump, distributer, etc. in my driveway. Is the head gasket replacement feasible for me? How long should it take a competent but inexperienced wrencher?
Finally, if I do it, or get the shop to do it, is there anything else I should look for or do at the same time? The motor has about 130k on it, and 45k since rebuild. The rebuild was basically mill where necessary, add a crank, and replace anything broken or worn. (no oiling mods, porting, etc.)
Matt
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-25-2001, 10:13 AM
Blown head gasket ?
Oh, I forgot to say that it is a 360 in my '73 F100...
  #3 (permalink)
Old 04-25-2001, 02:53 PM
Ratsmoker's Avatar
Ratsmoker is starting off with a positive reputation.
Blown head gasket ?
  #4 (permalink)
Old 04-25-2001, 05:46 PM
FE427TP is starting off with a positive reputation.
Blown head gasket ?
[font size="1" color="#FF0000"]LAST EDITED ON 25-Apr-01 AT 06:48*PM (EST)[/font][p]When you pull your dipstick does it have a creamy looking foam on it? And do a compression test as low compression on two adjacent cylinders is a usual signal
  #5 (permalink)
Old 04-25-2001, 07:35 PM
Blown head gasket ?
>foam on it?
No, not really. The oil looks very thin, but my pressure is much higher than normal. It's up around 70 at idle -- usually it sits around 20 at idle and up to about 50 when revved up.
>And do
>is a usual signal
My compression tester is at my Dad's, so I will do that tomorrow. Thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
