Holley list 9834/ fuel capacity - Ford Truck Enthusiasts Forums
Old 04-28-2001, 08:22 AM
bill ballinger bill ballinger is offline
bill ballinger is starting off with a positive reputation.
I have a carb I got from a guy who had no ide what it came off of. It's a 9834 number on it. I got a lot of info from Holley's website, but no application data.
Here's what I have:
List 9834
Style : 4160
Renew Kit: 37-720
Trick Kit: 37-933
Needle and Seat: 6-506
Primary Jet: 122-642
Secondary Plate: 134-39
Power Valve: 125-65
Discharge Nozzle: .031
Secondary Spring: Black
It has a Ford kickdown and an electric choke. I figure its a non-OEM replacement, but the 642 jet leads me to believe its keyed to an emissions application. It has the idle screws on the sides of the primary block, so it's a pre 80's application I think. If I remember right, 80's up had four corner idle. Not sure though. I found carbs listed that use the same kit but have a 68 jet under the numbers 6619, 9834-3, and 89834.
Anyone know what this came off of? My 390 is about to suck the Quadrajet I've had on it down the intake. The Q-jet runs great, and gets reasonable economy, but this engine wil pull every bit of the fuel out of the bowl in 5 seconds. It wants more fuel capacity. I'm running an Airtek 362 machanical pump (428 CJ) I'm thinking of kitting the Holley and jetting it at 68 to start and putting in an 8.5 power valve. My idle vacuam is 15.
Old 04-28-2001, 09:07 AM
pntrbil pntrbil is offline
pntrbil is starting off with a positive reputation.
Bill, here's a number for Holley tech support where you can talk to an actual person. 502-781-9741. They helped me ID a 2 bbl I found as 350 CFM from a V8 truck with a governor setup on it. U-Haul? LOL!
That same carb has had some major modifications and will be feeding my Pinto tonight at the local dirt track. It went from laying in a field to a, "most of the time", top 5.
Another Bill.
Old 04-28-2001, 04:39 PM
FE427TP FE427TP is offline
FE427TP is starting off with a positive reputation.
Proper jet size for Holley carb on nearly stock 302? WilliamKG88 Fuel Injection, Carburetion & Fuel System 3 06-18-2015 06:24 PM
79 e350 RV - will this carb work? HRE35079 1968-2013 Full Size Vans 2 05-09-2014 11:50 PM
Secondaries pegging rich, converted Holley 4160 wyckedcombo17 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-07-2013 12:06 AM
Holley model #? 79brncnwht Fuel Injection, Carburetion & Fuel System 9 01-16-2010 12:15 PM
problems with rebuilt Holley 3310 hatemakings/n Fuel Injection, Carburetion & Fuel System 58 06-21-2005 07:00 PM
Tags
1177, 9834, 98341, 98343, carb, carburator, carburetor, governor, holley, list, list98340907, model, number, trucks, uhaul
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
