Remote Start
best???? thats hard to say. afterall, most of what makes a unit good is the install. i have tried a couple different brands. my favorite is crimestopper, and my least favorite is bulldog. are you looking for a basic remote starter, or an alarm/starter/keyless entry? there are many units that will tie into factory security systems, and you can even use the factory remote as a starter ( as example, 3 pulses from the factory remote lock button will start my truck if i want). you just need to decide which features you would like to have. based on which vehicle you have (im assuming a newerr ford), you will need a PATS bypass module as well. will you be installing yourself, or having a shop do it? the units themselved are not that expensive, but installation can be. hope this helps some.
I also have the Crimestopper unit on my F-150, and am very satisfied with it. I can start the truck from quite a ways away, and it has never failed to work. I had it installed professionally, and feel this is the only way to go as there is too much that you could accidentally screw up........................................
Take a look at Compustar, This is the Cadillac of remote starters. I have had 8 vhehicle with remote strters and this has been the best brand I have bought. The range is increadible, and it starts every time.
http://www.compustar.com/
kilroy99
05-26-2018 01:06 PM
jimbomitch
29
04-04-2018 07:56 AM
90pioneer
6.7L Power Stroke Diesel
11-02-2015 11:48 AM
