Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
What to do with old F350 rotors?
Old 10-13-2007, 02:13 PM
mrc59's Avatar
mrc59
mrc59 is offline
Question What to do with old F350 rotors?
I replaced my rotors this weekend, and have the old ones. They're heavy and must contain pounds of recyclable steel. What do folks do with these old parts?
Old 10-13-2007, 02:25 PM
Bill W's Avatar
Bill W
Bill W is offline
Get a dog and you can play frisbee with them!! OK,, naw. dont do that, You got a Boat? they are good Anchor's
Hope you know I'm just kidding.
Old 10-13-2007, 02:34 PM
mrc59's Avatar
mrc59
mrc59 is offline
Or a collar tag for the dog you DON'T like. No, I AM kidding!
Old 10-13-2007, 05:27 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Depending on their weight, I have used them for grinder stands bases, counterbalance weights, even wheels for a welding cart.
If you don't have any use for them yourself, put them in the free section on Craigslist. Someone will pick them up.
Old 10-13-2007, 06:15 PM
frederic's Avatar
frederic
frederic is offline
They're useful for many things. Some suggestions you've already received.
After I changed my last pair out, I saved the one that was in reasonable condition for use as a wood chipper flywheel. The plan is to make four 3/4" wide, angled slots and mount chipping knives over that slightly overhanging the slots.
Mount that to a large diameter shaft (3") with a 1/2" thick metal plate to bolt the rotor to, and drive all that with some pulleys and a 3600 RPM lawnmower engine of reasonable size.
Yes, that's the foundation of a homemade wood chipper. The case it will be in will be made of bent 1/2" thick plate for safety reasons.
Old 10-13-2007, 09:21 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Ya know, if it was anybody else doing that I'd probably tell them they were insane- But, we all know you are so I won't repeat it!
Old 10-14-2007, 12:43 AM
yamaguy's Avatar
yamaguy
yamaguy is offline
Set them out for the junk man. Thats all they are good for. imo
Old 10-14-2007, 02:30 PM
Flatdeck's Avatar
Flatdeck
Flatdeck is offline
Take them to the steel recycling place, along with your other scrap steel. They'll even pay for it.
Old 10-14-2007, 06:24 PM
herman391's Avatar
herman391
herman391 is offline
Paperweight???
Seriously if you have enough other scrap metal lying around to make it worth while I would take them to the scrap yard and get a few extra $$$$
Old 10-14-2007, 09:34 PM
frederic's Avatar
frederic
frederic is offline
metal recycling centers typically pay anywhere from $4 per hundred to $7 per hundred. One place near me pastes "todays rate" on their sign at the main road, so if it looks decent enough I'll load up and haul a pile over.
The last load I dropped off was "heaping", and almost 3000 lbs. Got about $220 or so.
1/2 filled up the truck, the other half paid my cable bill LMAO
Old 10-15-2007, 03:05 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
You could use them as bases/stands for signs. Weld the pole to the rotor. I have seen that at car places. Makes them to heavy to just walk away, yet easy enough to move.
Old 10-15-2007, 03:13 PM
bigrigfixer's Avatar
bigrigfixer
bigrigfixer is offline
The Pacifier
If they are still in spec, turn them, and save them for your next brake job. That's what I do. Always have spare rotors for the brake jobs, so I don't have to try and get a spare car to get them turned.
Old 10-16-2007, 01:58 PM
mrc59's Avatar
mrc59
mrc59 is offline
These are great ideas all. Thanks for the help!
Old 10-17-2007, 02:26 PM
seventyseven250's Avatar
seventyseven250
seventyseven250 is offline
I love the chipper idea, in fact, I'm fascinated and impressed by all your stupid and crazy ideas.
at seven bucks a hundred, I'd guess those two rotors would score me . . .around a buck?
I think I'll probably toss them. they can rust at the dump.
Old 10-17-2007, 03:07 PM
1975Ford's Avatar
1975Ford
1975Ford is offline
and Those rotors make for some good wheel / tire blocking.
Quick Reply: What to do with old F350 rotors?
