Are these tailgate chains on properly? 1960
Wow this was so long ago I had forgot about it.
I never figured out why the loop was too big. I ended up shortening the loop. I cut out a section on each side of the loop, too long ago to remember how much, welded them back together and ground and polished the 4 welds. They hold nice and tight now. See pictures.
Note the hook stays in better if you feed it through the hole the other way, but this is the picture I already had on the computer.
Either the ears on the tailgate are too close to the edge of the tailgate or the bolt that holds the chain is too close to the tailgate. In 99 when I first painted my truck I got a good used tailgate from California that had the ears cut off. The man I bought it from welded them back on. One was a bit too close to the edge of the gate and that clasp was loose. When I got it repainted this past winter I had my bodyman move the ear father away and that solved it.
The one on the passenger side was loose and now is fixed.
Are the styleside chains and clasps designed slightly different?
Those books won't bounce out. They were put in upside down and then put the whole way through as you see them in the pic. The way the hooks are on my tailgate would sooner house out but that has rarely happened.
We have several stepside Fords And more Chevys in the local club. Most of the retailers say one style does all stepside Fords. I bought a set from Mark K in Oklahoma City. My tail gate is an after market Taiwan. Mark K had a set that worked nice and tight with the rubber bumper that sets against the tail gate to the inside. I looked at other trucks, all F-100s and most are different. From my 55. AJ.
gthbryce
29
06-01-2021 11:13 AM
nigcar(abbreviation)
1999 to 2016 Super Duty
07-09-2016 05:01 PM
