Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-13-2007, 10:12 AM
itswrongway is starting off with a positive reputation.
Red face pcv vavle
I hope this isn't a dummy like question but where did ford hide the pcv vavle on a 2001 escape v6 3.0 ?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-15-2007, 12:10 AM
2fords2 is starting off with a positive reputation.
It is on top of the engine under the throttle body on the drivers side. Tough to reach. You'll need a long needle nose pliers or wrench to reach it. Moving the air filter housing and snorkle out of the way helps with access. Unscrews about 3/4 of a turn to the left, then pull it out. I simply stuck a 7/8 (I think it was, not positive) open end wrench way in there and twisted the valve as if the wrench were a screw driver...if you can picture that.
  #3 (permalink)
Old 03-16-2008, 07:34 PM
ptb6744 is starting off with a positive reputation.
I couldnt find it and I had the top of the engine all part to change all the spark plugs and coil on plug sets..
  #4 (permalink)
Old 03-16-2008, 10:38 PM
Take a look at this picture with the filter housing and big intake tube removed ...
PCV Location
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
