Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Ranger & B-Series
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 10-12-2007, 10:27 PM
goodwrench is starting off with a positive reputation.
will running with a wacky oxygen sensor
Cause any harm other than gas mileage? If you read my other post i have been fighting a totally stuck o2 sensor, that i have fubared. I read the codes toninght and got three pending, p0135 p1131 p1132. i need to drive it some till i find me a compentent mechanic to help get the old sensor out.. Will i do any harm other than the fuel mileage if i drive it?? I dont want to foul a cat or harm the motor. It seems to run the same, and the exaust doens't seem to smell any different.. So anybody know? Will these problems with the o2 cause any problems if i drive it some??
later!! chris
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 10-12-2007, 10:35 PM
DesertStorm's Avatar
DesertStorm is gaining momentum as a positive member of FTE.DesertStorm is gaining momentum as a positive member of FTE.
you dont have to fight getting that o2 out. Get a new sensor and match up a nut with the same threads. Drill a hole about 1 inch away from the old sensor in the exhaust large enough for the sensor probe fit into. Weld the nut over the hole. Install o2 sensor. Plug in. Done. Shouldnt take more than 30 min if you are good.
  #3 (permalink)
Old 10-12-2007, 10:54 PM
Peter94's Avatar
Peter94 is gaining momentum as a positive member of FTE.Peter94 is gaining momentum as a positive member of FTE.
Or you could just heat the old one with a torch and loosen it.
According to PO 135 it indicates either a short or an open circut. Check to make sure none of the wiring is damaged.
__________________
88 4x4 300 six, 5spd. granny 1st, reg cab 3.55
85 4x4 5.0L F-One Fiddy Reg Cab 3.55 With a Flatbed
^Now that its 21 years old, it can smoke and drink!^
  #4 (permalink)
Old 10-13-2007, 01:40 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
I would say over 90% of damaged cats are due to bad o2 sensors, and that over 90% of those did not have O2 sensor codes. Change the sensor, it costs less than the cat, and also gas isn't cheap these days. You can drive it some, but don't put it off.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
