You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I'd post a few links for you, but the website is temporarily down right now.
You won't need a parts list because in taking the S/C off to get to the IC, you won't be removing anything that needs replacing. Everything is reusable.
The gasket between SC and midplate is metal and can be reused.
The gasket between the midplate and lower intake manifold is metal and can be reused.
All the bolts are reusable in this area and dont need to be replaced.
DO NOT seperate the IC from the Midplate. Those bolts are torque to yield and cannot be reused, plus you will most likely damage the gasket because it's not metal.
There is no reason to seperate the IC from the midplate in order to clean the IC.
Send me your email, I have the instructions saved to a Word doc I'll send to you in a zipped file.
Stewart
StarGazr9z at aol dot com
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
When me and three of my L buddies got together one weekend and held an IC cleaning party, we'd presoak the IC with Easy Off oven cleaner first. Then we'd clean the IC with carb and brake cleaner and compressed air.
This was my IC before cleaning it.
Back of the throttle body.
Underside of S/C.
Valley after IC has been removed.
After its been cleaned.
Stewart
I got mine off tonight ( not too bad at all). Mine is nowhere near as dirty as your was (suprising). I can't post pics but I'll send you some is you want.
Thanks for the help
Greg
Thanks for the help
Greg
Greg, I can host them for you if want. Or go to Photobucket.com and using their very user friendly interface, upload your pictures yourself and then post them here.
What year is yours? Mine was a '99 that I bought used with 72K miles on it.
Stewart
