Cylinder Heads....which one's
I have two different sets of heads for a 360/390 and I was wondering if anybody can tell me what the specs are on them and which one's would be better.
one set has a casting of D2TE-AA
the other set is C3AE
Also, The C3AE heads came with adjustable rocker arms. Are these rockers interchangeable between the two
The D2TE-A heads are common heads that were used from 1972 until 1976 in trucks with 360, 390, and 428 engines. 68.1 to 71.1cc chambers, and 2.02" intakes and 1.55" exhaust valves.
The C3AE number is incomplete. Look at the heads again and read on both sides of the spark plug. The number should be something like C3AE 6090 with another letter behind it. These are High Performance heads from either a 406 or a 427.
The rockers will interchange, but you'll need new pushrods. A standard FE uses rods with a ball on both ends. The adjustable rockers need rods with a ball and a cup.
Get back to us with the complete casting number of those C3AE heads. By the way, I can store those for you! :-)
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Jason Kendrick
trozei
40
09-12-2020 09:22 PM
jaywischmann
16
05-17-2013 06:27 PM
JimNolan
01-26-2010 05:47 PM
mswift
12-21-2006 01:42 PM
oldmansimek
03-09-2006 10:42 AM
