Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 10-12-2007, 01:41 PM
DJOHNSTON78 DJOHNSTON78 is offline
Garage is empty, add now
DJOHNSTON78 is starting off with a positive reputation.
Propane for Daily Driven Ford 400
wondering if anyone has ahd experience with propane on a stock 400 or equivilant engine. And how was the difference in mileage, power and drivabilty. Where is a good source to get a kit for daily useage?
  #2 (permalink)
Old 10-15-2007, 08:59 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Propane as the primary fuel will yeild less power and reduced MPG than gasoline, regardless of the engine.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 10-15-2007, 10:39 PM
o7dgm o7dgm is offline
o7dgm is starting off with a positive reputation.
If you increase the compression in your engine you get the same or better.Propane is 104 octane so it needs higher compression .
  #4 (permalink)
Old 10-17-2007, 12:53 AM
gotfu gotfu is offline
gotfu is starting off with a positive reputation.
generally power and mileage will be reduced by 20%.
__________________
2004 f350 cc lb 4x4 4"turbo back,autometer gauges, 12000lb fiver
  #5 (permalink)
Old 12-03-2007, 11:42 PM
hotroddually's Avatar
hotroddually hotroddually is offline
1974 Ford F-350
My Garage
hotroddually is gaining momentum as a positive member of FTE.hotroddually is gaining momentum as a positive member of FTE.
just because its propane fuel,does not mean you will have less power. propane fueled engines are fine for power if they are higher compression. mine is better for power now on propane, than it was on pump fuel.propane is a higher octane than pump gas,so if you have an engine like mine(428 SCJ ,12:1 compression) it runs better on lpg than pump gas. i was mixing 94 octane and av gas just to get good power and no preignition before converting to propane.lower compression engines or worn engines are not as "happy" on propane,so you won't get as good results with them as you will with a higher compression engine.as for mileage,mine was always bad,4-5 mpg.thats not the normal mpg,but my truck is not my daily driver so it doesn't bother me.my engine has big horsepower/torque that was my need more than good mileage (so it doesn't matter to me)this has bin my experience anyway.
__________________
1974 f350 4x4 dually 428scj,-HOOF BEATS ARE LOUDER THAN HEARTBEATS!
2001 ranger xlt supercab 4x4
2008 ford escape xlt
2004 f-150 supercrew FX4
2006 harley davidson softail fxst; -'05 suzuki quad
2006 wells cargo roadforce trailer (my toy hauler)
  #6 (permalink)
Old 12-18-2007, 07:07 PM
fraso fraso is offline
fraso is starting off with a positive reputation.
Were you looking for a mono or dual fuel kit for your truck?
  #7 (permalink)
Old 12-19-2007, 09:41 AM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
The basic problem with "conversions" or "flex-fuel", "bi-fuel", etc. is that the engine itself, compression, timing curves, etc are still setup for 87 octane unleaded gasoline. You will always lose power and mileage this way.
Jim
  #8 (permalink)
Old 12-19-2007, 10:07 AM
You're right, you will lose some power and mileage on propane. But what's more important: mpg or $/mile?
Typically, conversions with the Impco propane systems get somewhere between 75% to 80% of the vehicle's gasoline economy. If you get 20 mpg on gasoline, you'll get around 15 - 16 mpg on propane.
The overall savings comes from the difference in fuel price and the price of propane depends a lot upon where you live but Flying J truckstops usually have cheap LPG. If you can buy propane for $2.00/gallon and gasoline is selling for $3.00/gallon, your truck running on propane will COST you as if it were getting 22.5 - 24 mpg on gasoline. That is:
15 x 3/2 = 22.5 and 16 x 3/2 = 24
Obviously, if you need high octane gasoline for your vehicle, propane makes even more sense. Remember, propane has an octane rating of 104.
Newer commercially available injection systems get closer to 80-90% of a vehicle's gasoline economy but these systems only work with an existing gasoline EFI system.
Whatever you do, do NOT use portable DOT lift truck tanks on an on-road vehicle. They are illegal and dangerous for this purpose.
  #9 (permalink)
Old 12-20-2007, 12:53 PM
BEWOLD's Avatar
BEWOLD BEWOLD is offline
BEWOLD is starting off with a positive reputation.
propane is a good choice for the enviromentally concious person, its cleaner burning and non toxic if spilled. Being cleaner burning it is also better for the engine internals (less carbon build up and oil contamination) longer plug life as well as longer oil change intervals saving you even more money.
__________________
96 F150 reg cab sbx 5.0 5spd 4x4, 3 body/ 2 susp, 35 boggers, 3.55LS, mass air, K&N drop in, stock cats no muffler. 2000 F-550 crew handshaker. 2012 F450 crew
  #10 (permalink)
Old 12-20-2007, 01:12 PM
If you're stuck in traffic, propane can also save you time because some highways allow alternative-fuelled vehicles to travel in the high occupany vehicle (HOV) lane.
  #11 (permalink)
Old 12-20-2007, 04:41 PM
It can also cost you time and money if you have to drive miles around because you are not allowed in certain tunnels.
HOV stickers are given for CNG in CA, but not LPG.
Jim
  #12 (permalink)
Old 12-21-2007, 10:12 AM
1978Crew 1978Crew is offline
1978Crew is starting off with a positive reputation.
In AZ, i believe the HOV sticker is given for JPG as well.
__________________
1978 F250 2WD Crew Cab 351M/ C6 - SOLD
1999 F250 2WD CC LWB 7.3L 4R100: Door Ajar light Fixed, Power Locks Fixed, Rotella T6 Synthetic, Fuel Bowl Seal Kit
  #13 (permalink)
Old 12-23-2007, 10:12 PM
68f250360 68f250360 is offline
68f250360 is starting off with a positive reputation.
i have a 95 f250 with a 7.5L and i run it on propane all the time because i get way better mileage compared to running it on gas.
Tags
400, ford, mpg, propane
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
