97 F150 odometer/tripcounter not working - Ford Truck Enthusiasts Forums
Old 10-12-2007, 11:00 AM
Forced347sn95 Forced347sn95 is offline
Forced347sn95 is starting off with a positive reputation.
Got a 1997 f150 97 is analog not digital so there is no blackout. Got the truck like this with the problem. It worked one morning then i pushed the reset counter and it stopped. I took out the gauge cluster and spun the gear i think by a tiny motor and the tripmeter worked along with the odometer adding a mile. So I know the gears are not striped. Any info??
Old 10-12-2007, 01:53 PM
razorback234 razorback234 is offline
razorback234 is starting off with a positive reputation.
Odometer/Trip Counter
I have to same problem with a F250LD, I havent pulled out the cluster yet
because I not sure of how to remove the dash panels, any advice.
Jim
Old 10-12-2007, 01:58 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i dont know about the F150, but the boy had a 95 Mustang with similar problem. The speedo worked, but odometer did not. took it apart and it had a stripped racka nd pinion gear. I know you said it is not the gear, but i would check to see if the speed and odometer have the same input. If the speedo works and the odometer does not, that narrows it down to the small gear box, i think.
Old 11-09-2007, 08:56 PM
Question Odometer/Trip Counter
I have a simular problem but I cant figure out how to remove the worm gear
and replace it with a new one. Any hints
Old 11-09-2007, 10:03 PM
chrisf250-460 chrisf250-460 is offline
chrisf250-460 is starting off with a positive reputation.
my 98 f150 trip counter has stopped before and it wouldnt reset but after driving a few miles i guess it would move away from the bad spot on the gear and start working again. ithought it was just my truck.now i know im not alone
Old 11-10-2007, 05:22 PM
RedDragon777's Avatar
RedDragon777 RedDragon777 is offline
RedDragon777 is starting off with a positive reputation.
yeah my sisters 95 mustang GT does not work any more, i am hopeing not have this problem with my 97 F-250 and i am lucky my 06 mustang GT is digital
Old 11-11-2007, 04:03 AM
I would say to check if the gears are the same as the 94-98 mustangs and if they are then it should be no problem finding a 94-98 guage cluster at a junk yard
Old 11-11-2007, 06:27 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Think it could be the cable down to the t-cast/tranny? Or the gear in the tailshaft?
Old 11-12-2007, 07:33 AM
I need to know how to get the worm gear out of the odometer/trip meter
Old 12-13-2007, 03:02 PM
Thumbs up Odometer/Trip Counter
I was finally able to remove the cluster and found the gear causing to
problem it was missing a tooth but it took along time to figure out how
to remove the gear, finally got the gear replaced and the instrument
panel back to gether and found that the gages were off, so after
spending some time trying to calibrate to gages, I gave up and went
online and found a used one with almost the milage on mine.
The price wasnt bad compared to what they wanted to repiar mine
/////approx 200.00 ///////////125.00 for the used one.
I really appriciated all the posts I got trying to help me.
Old 12-13-2007, 05:21 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
bigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to beholdbigdaddyII is a splendid one to behold
I ended up having to buy one from a junkyard for the same problem. Although my truck has almost 225,000 miles on it my ODO says 67,000 miles. I did have to put a sticker on my drivers door jamb though stating the correct mileage.
97 F150 odometer/ trip meter Wayne J 1997 - 2003 F150 6 07-18-2016 09:39 AM
97 F-150 with Motor driven odometer Thudpucker 1997 - 2003 F150 0 11-30-2014 12:10 AM
97 econoline odometer ? gyrocopter1 1968-2013 Full Size Vans 7 12-21-2012 06:47 AM
95 F-150 speedometer and odometer stopped working simultaneously Authenticraft 1987 - 1996 F150 & Larger F-Series Trucks 17 03-28-2010 05:59 PM
odometer problems 97 f150 Brian Lawrence 1997 - 2003 F150 3 09-14-2007 11:48 AM
Tags
1997, 42, 97, 98, doesnt, expedition, f150, ford, gears, meter, odometer, quit, speedometer, trip, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
