Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-11-2007, 09:02 PM
Kalashnikov Kalashnikov is offline
Kalashnikov is starting off with a positive reputation.
Supercharged 300
Bought an Eaton m90 supercharger from a Thunderbird to try on my 94' F150 4.9l 300. I know it isn't the greatest choice for the engine, but it was cheap and would still be worth doing. I'd like to run 10psi from it and possibly add an intercooler later on. I'm going to see how EEC responds with the stock injectors but will probably switch to 19lbs eventually. I'd like to stick with the stock SD EEC so if it responds too erratically I suppose I will have to reprogram it. It should be exciting.
  #2 (permalink)
Old 10-12-2007, 08:20 AM
phil6608's Avatar
phil6608 phil6608 is online now
phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of phil6608 has much to be proud of
Sounds like an interesting project!
Good luck with it and let us know how it's coming along.
__________________
Phil
2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 16 PSI
BTS/4R100 tranny/100 shot nitrous
1.68 60' time/11.76 @ 116.17
  #3 (permalink)
Old 10-12-2007, 08:40 PM
keyul keyul is offline
keyul is starting off with a positive reputation.
i would love to hear how this project turns out! your 300 will be even more of a torque monster, please do keep us posted!
__________________
Kyle
82 f150, shortbed, step side, 300I six, 4x4, 4 speed
  #4 (permalink)
Old 10-14-2007, 10:39 PM
SR_Crewchief SR_Crewchief is offline
SR_Crewchief is starting off with a positive reputation.
Quote:
Unfortunetly, your going to have a host of problems without doing more than just adding the SC. The stock programming just can't handle what your proposing to do.
Second thing that comes to mind is: The stock 1 BAR MAP sensor will be max'd/out of range as soon as you have actual boost as a starting point.
Third thing is: The stock fuel delivery isn't set up to boost reference increased delivery.
The single biggest hurdle to overcome is the programming. I've yet to find anyone that has gone through the hassle of cracking the tables for any of the SD 300. You'll probably be better off going with an aftermarket ECU like the new one from Accel DFI. Be prepared to shellout a minimum of $1200 for a unit to run your engine.
With engine management handled the rest is doable. Without it...
__________________
1988 F150 std cab LB 4x2 300/4.9l M5OD 3.08's 288,000+ original miles.
Tags
300 , 49l , eaton , ford , m90 , sc , supercharger , thunderbird
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
