e40d to c6 - Ford Truck Enthusiasts Forums
e40d to c6
Old 10-11-2007, 05:43 PM
larry1211's Avatar
larry1211 larry1211 is offline
larry1211 is starting off with a positive reputation.
e40d to c6
ok I cant figure out what is wrong with my e4od tranny so I would like to swap my e4od for a c-6 tranny...can someone tell me what I need to do to do that (if it can be done) I really don't want to put any more money into this p.o.s tranny.
It has been rebuilt 2x in 2 years. I would really like a tranny that I can count on and I think the c6 is my best option,,,,,I just don't know what is involved in doing it. any help would be greatly appreciated. I really don't need the 4x4 cause I never use it, if it will work on the c6 than i will probably use it....it a borg warner 1356
I have a 1992 ford f150 4x4 e40d eec-iv
Old 10-11-2007, 11:25 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
I've seen way too many successful E4OD rebuilds that would steer me towards rebuilding mine if I needed it vs. changing towards a C6.
The ECU you have will look for an E4OD so a minor tuning change will be needed (something to tell the ECU that it's in N). You have to move your trans cross member, find another driveshaft and get used to not having OD.
Old 10-11-2007, 11:55 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Find a trans shop that will stand by its work. C6's break too, and if they are old and used up, and the same "repair" job is done on one, it'll be junk too.
Old 10-12-2007, 01:24 AM
NewF100 NewF100 is offline
NewF100 is starting off with a positive reputation.
If properly built the E40D is a great transmission. If your truck is lifted a gearing change might be necessary, or if you have a ton on power you might need a shift kit. But I have seen these transmissions take 200,000 no problem.
E4OD using stand alone diesel TECA 4x4slik 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-18-2016 08:55 AM
e4od donor truck swap? father6 1987 - 1996 F150 & Larger F-Series Trucks 1 07-07-2015 09:48 PM
Transmission Surprise, C6 not a E4od? windyhill 1987 - 1996 F150 & Larger F-Series Trucks 26 11-13-2010 06:20 PM
which od tranny should i use? ncl Clutch, Transmission, Differential, Axle & Transfer Case 16 01-25-2007 07:49 PM
c6 swap into 94 E40d DictatorDanny 1987 - 1996 F150 & Larger F-Series Trucks 12 06-15-2006 08:44 PM
Tags
1992, c6, duty, e40d, ford, home, motor, needed, super, swap, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
