6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
what exhaust should i instal on my 6.4 f-350
Old 10-13-2007, 04:50 PM
stroke this's Avatar
stroke this
stroke this is offline
Originally Posted by bnmccoy
https://www.fleet.ford.com/truckbbas/non-html/2008/whatsnew2008.pdf
If you go to page marked 27 or (Adobe page 29 of 56) you will see a drawing of the exhaust system which shows what can be modified. Basically you can modify between the DPF and the cooling diffuser twin tips; with warning to not increase the back pressure.
I CAN'T SEEM TO GET THAT LINK TO WORK BUT, I'M INTERESTED TO SEE WHAT IT IS AND WHERE IT CAME FROM, I WOULD REALLY LIKE TO PUT A 4 0R 5 '' ON MINE. CAN YOU POST IT AGAIN?
Old 10-13-2007, 07:48 PM
bnmccoy's Avatar
bnmccoy
bnmccoy is offline
I think your post came about before I finally had it edited to work. Some problem because it was https vs http. Link in my post quoted in your reply does not work but my original edited post should have good link now.
Otherwise go to www.fleet.ford.com/truckbbas/
and the "whats new for MY2008" link is towards lower left.
Bob
Old 10-13-2007, 08:13 PM
DMAX-HD's Avatar
DMAX-HD
DMAX-HD is offline
Originally Posted by stroke this
I SEE YOUR POINT BUT IT REALLY DOSN'T MATTER WHAT WE THINK IF FORD DOSN'T SEE IT THAT WAY.
It's kinda a 'wishy-washy' deal all the manufactures have in regards to exhaust system on dz with the new emmisions crap. Exhausts wear-out - so if their going to void warranty if we change them maybe 'they' should cover the repalcement of them as well.
Just for clairifcation I am only talking DPF-back not turbo-back
Old 10-15-2007, 10:12 PM
SANDDEMON08's Avatar
SANDDEMON08
SANDDEMON08 is offline
I think this will clear things up on what can and cannot be modified. Look at page 27 of this PDF from ford. It outlines what can be modified on the exhaust.
www.fleet.ford.com/truckBBAS/non-html/2008/whatsnew2008.pdf
Old 10-16-2007, 10:12 AM
captaineddie's Avatar
captaineddie
captaineddie is offline
What is the purpose of the slots in the exhaust tips. Are these essential for the exhaust to work properly?
Old 10-16-2007, 11:20 AM
stroke this
yes, they are for cooling porposes.
i read an article about sucessfully removing them with no issues but the size pipe was upgraded.
Old 10-16-2007, 04:10 PM
rallem's Avatar
rallem
rallem is offline
That was great, now I know that I cannot modify my exhaust and that it is a 4" exhaust all the way to the end, unlike my friend's dodge which was 4" up until the end and then for some reason stepped down to a 3" exhaust.
Old 10-19-2007, 04:13 PM
gates13's Avatar
gates13
gates13 is offline
just got the dual mbrp exhaust system nice tips and truck runs alot better but not a noise exhaust
Old 10-19-2007, 04:39 PM
DMAX-HD's Avatar
DMAX-HD
DMAX-HD is offline
Those slots are for mixing cool air into the flow before the air actually reaches the tip. It also helps in the Venturi effect (Bernoulli's principle)
Also please note by my Avatar how GM really couldn't have screwed this up anymore. The pic was taken prior to the MBRP cool duel installation. The GM factory exhaust and tip look like a musket. What did the think - we was hunting 'wabbits' ?
Old 10-19-2007, 09:52 PM
gates13's Avatar
gates13
gates13 is offline
Cool
what can i do t i just got is not my exhaust instaled dual 4 inch mbrp cat back and its not loud at all its almost the same as stock
i have the bully dog chip and afe cold air the only thing i hear is my cold air
Old 10-20-2007, 01:32 AM
richardndawnc's Avatar
richardndawnc
richardndawnc is offline
I removed DPf and drove to shop open exhaust and still sounded like an escort , nothing will make it louder than that , and I could still hear the tires sing at 75mph it was so quite! But had to replace the DPF for now until I can get someone to turn off the regen cycle, it just blew out alot of white thick smoke.
bkuuz1
11-24-2010 11:30 AM
Franklin2
05-11-2001 08:41 PM
slim_vela
13
04-27-2001 01:21 PM
bigsix
02-23-2001 10:20 AM
priley
Exhaust Systems
02-06-2001 12:49 PM
Quick Reply: what exhaust should i instal on my 6.4 f-350
