How to start using WVO or BIOdiesel. - Ford Truck Enthusiasts Forums
Old 10-10-2007, 10:19 PM
442john 442john is offline
442john is starting off with a positive reputation.
Question How to start using WVO or BIOdiesel.
I just got my injector pump and injectors rebuilt and was wondering how I could start using waste resterant oil for fuel without hurting these new parts. I was also wondering if anyone in Knoxville, TN. has had success and how they started. I have a comercial location I could set up my operation but I want to do it right the first tim. Any advice would be helpfull.
Old 10-11-2007, 11:05 AM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
OOOOPS double posted
Mr Moderator please be so kind as to delete this post. It was inadvertant.
Old 10-11-2007, 11:07 AM
Phydeaux88's Avatar
WVO and Biodiesel are really quite different in their use.
To start using BD from a commercial source just pull up to the pump fill your tank and drive off. Go by the parts house and buy a new fuel filter, to have on hand incase the current filter plugsup. Throw the new filter under the seat and remember to install it after the first tank of BD.
To start using DIY BD you will need to build a processor. This web site will get you started and teach you everything you must know.
http://www.biodieselcommunity.org
Once you have done the research come back here and ask questions. One of our resident contributors, FABMANDELUX, is a bona fide expert on the topic.
To start using WVO you are going to have to install some mods on the truck, WVO must be heated to avoid damaging your engine and you should start up and shut down on good ole #2. These guys have a pretty good system and one of their guys hangs out here.
http://www.dinofuelalternatives.com/
be careful what you buy for WVO conversion there is some real junk out there.
Old 10-12-2007, 09:49 AM
firemediceric's Avatar
firemediceric firemediceric is offline
firemediceric is starting off with a positive reputation.
Quote:
No mention of Blending??????
Tags
bio, diesel, engines, ford, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
