88 f150 fuel system diagram? - Ford Truck Enthusiasts Forums
Old 10-10-2007, 08:55 PM
js2743 js2743 is offline
js2743 is starting off with a positive reputation.
i need a fuel system diagram for a 88 f150 short wheel base that just had the one fuel tank any help would be great.
Old 10-10-2007, 10:02 PM
JLDickmon's Avatar
JLDickmon JLDickmon is offline
JLDickmon is starting off with a positive reputation.
not much to it... tank, lift pump, line, supply/injection pump, line, injector rail, injectors, regulator, return line..
whatcha doin?
Old 06-19-2014, 01:12 PM
Lazarus88 Lazarus88 is offline
Lazarus88 is starting off with a positive reputation.
Dual / Single tank conversion
To renew an old thread here, any help would be appreciated.
My HP inline pump has been overheating, My thought was lack of fuel supply. Pulled line BEFORE Dual tank fuel reservoir assembly, grounded fuel pump on connector and got 8oz of gas in 5 seconds. Good in-tank pump. Reconnected and tested the engine supply port of the reservoir assembly, same method, 2 oz of gas. Bad reservoir assembly. The previous owner had removed the midship tank. QUESTION: can I take a fuel line from in-tank pump directly to the HP in-line pump? Do single tank F150's have a reservoir assembly, or some form of check valve? I don't plan on putting in another tank.
Old 06-19-2014, 04:16 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Yours is very similar to this diagram for an '89:
Wiring diagram airborne0130 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 02-25-2015 04:53 PM
88 F150 stereo connector pinouts benutne 1987 - 1996 F150 & Larger F-Series Trucks 5 11-08-2014 06:35 PM
88 5.8 f150 4x4 vacuum diagram mgates1964 1987 - 1996 F150 & Larger F-Series Trucks 1 08-08-2014 11:13 AM
98 f150 Diagram Request 88-150 1997 - 2003 F150 6 07-26-2014 11:36 AM
1988 ignition wiring diagram lasthighboy 1987 - 1996 F150 & Larger F-Series Trucks 3 07-25-2014 04:13 AM
Tags
1987, 1988, 1996, 50l, 87, 88, 97, diagram, f150, ford, fuel, gas, line, schematic, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
