Ford Sterling 10.5 open to posi conversion
I have a 2000 Ford F-250 4X4 7.3 6sp 3.73 ratio with a open ( "one tire fire") rear axle!!! My buddy wants to sell me an original posi-unit from at 2003-2004 F350 srw 4x4 w/ 3.73 gear ratio truck!!! My question is will this unit work on my axle even if the posi is from a 2003 or 2004 truck???????????? What else would anybody recommend or say about this?
Thankyou
Luke
Thankyou
Luke
Thankyou
Luke
Thankyou
Luke
Originally Posted by rebelchevy02
If they are both SRW trucks and both 3.73 like you said, then yes it will work, as they both have sterling 10.5 axles.... I personally dont think its worth the time or effort. The factory installed limited slips are hardly worth their weight as a paperweight IMO. Every one of our trucks hasnt had a limited slip since around 80k miles. At which point it was pretty much an open diff. I would look for a better traction device, as there is so many to chose from. I got a detroit locker for mine, and absolutely love it, but for the average empty street DD I would say its too much also. I would look into an eaton posi or a torsen limited slip if you want limited slips. As for lockers, ARB or Detroits for me. Have had good luck with both. If you get the limited slip for under 50, and know someone who your confident can do your swapout for a case of beer, it might be worth it, but I wouldnt put another one of those oem ford limited slips in again. (auburn posi IIRC)
Well how many miles are on the posi, and how much is he going to sell it to you for? If you dont drive much, or pretty much stick to the roads, it technically is better then an open diff, if you go around a hard turn, and floor it, it will more then likely still spin one wheel. power brakeing will usually be both, gravel roads with equal traction will probably be both, one wheel in the stones and one on pavement will mean spinning in stones, virtually no power to the pavement. Me, I dont even want to see another one of the factory limited slips in my life, they do just that, sliiiiiiiiiiiiiiiiiiiiiiiiiiiip.
No, I am in the same boat as you right now and following this thread. I do not like how my rear diff behaves either. I too am waiting.
Patience my friend, someone will be along. Rebel is just telling you what he knows. I don't like the $ figure either so maybe someone else will be along with a better mousetrap or I will live with mine.
BTW, my rig has 60k miles and I don't like one tire fire either.
Originally Posted by SolidGround
Detroit Locker, hands down. A little noisy in low-speed manuevers, but trust me, when it comes to layin' 'em down... it's four big black ones from me!
I love dually burn-outs! Someone once asked, "why the garbage man always locks 'em up in front of my house?"
hey rebel i took your advise i am going to go with the Detriot truetrac limited slip it has no cluthes or gears to burn out!!! It has planatary gear and requires no special limited slip additive!!! I talked to a buddy of mine is says that i full locker is not for me since i do alot of towing he said i just need a really strong limited slip!!! So i guess for 510.00 is not too bad!!
To answer your question, they will work, as long as they are both SRW or both DRW axles. You will just need to take the ring off the carrier unit of your current case, and swap it on to the posi unit. Reason being ring and pinions are a matched set, they are ran together to be sure they mesh correctly. You can't take the entire posi unit with the 3.73 ring off the other truck and swap it in yours unless you also swap out the pinion also. You will need other tools to set it up, but its fairly simple to do.
...The thing to remember, is if your having an issue were only one tire is spinning, if you slightly apply the brakes to put resistance on the wheel thats spinning, it will lock up, and ahoy forward you go! That is just the most important thing to remember about the torsen style (detroit truetrac) differentials...
Originally Posted by JoeTrotter
Are those the same diffs that Humvees use? Maybe someone will chime in, 'cause I know that the brake throttle modulation works like a charm on humvees, and not much else.
http://www.amgeneral.com/vehicles_hmmwv_models_a2_components.php
