Ford Sterling 10.5 open to posi conversion
Originally Posted by fd1109
What are the advantages/disadvantages with the locker vs limited slip (Detroit) ?
Advantage of limited slip: More street friendly...it does allow the inside tires to turn slower on turns when you are on the throttle.
Advantage of locker: Ultimate traction. On the street, if you corner hard you will chirp the inside tire. When you are on the throttle with a Detroit Locker it locks both axle shafts together, when you coast they unlock. On a long wheel base vehicle like a SD especially with an auto trans, it's not as big a deal as on say a stick shift jeep.
Of course you also have selectable lockers like ARBs, that are basically an open diff when they are turned off, but flip the switch in the cab and it's like a spool.......axle shafts are always locked together when they are on.
7.3stroker2215
03-30-2022 11:58 AM
deckertd
05-18-2017 01:03 PM
outlaw128
1999 to 2016 Super Duty
01-12-2016 06:41 PM
SWAT KHAN
1997 - 2003 F150
06-05-2012 02:29 AM
