"Harsh Ride"
"Harsh Ride"
Ok, how the hell do you calm this truck down. I owned a 97' Chev Siverado 4x4 CCLB with a 6 inch lift...drove like a cadilac down the hiway...real smooth. Now I have a 2005 F350 CCLB 4x4 V10. I put a spring leveling kit, new Ranchos in the front added Toyo MT 35x12.5x18 tires, alignment and its so ruff on the hiway that my shoulder is killing be resting it on the armrest.
OK...I know I have a few issues...1st, toss those shocks...I was in a pinch and thats what was available at the time..What do you recommend..in reason.
The springs I put in had a larger diameter coil...good if you plan on carry a camper on your back, but to stiff for a gas rig..I think?? I was thinking of putting the stock springs back with the spacers. Does someone sell a progressive spring without havin to buy there kit?? How much heavier is the diesel verson of this truck.
I have tried messing with the tire pressures..and I think when I got it to 35psi it got worse. You can drive through the rough part...alot has to do with the wheelbase catching those rivits in the road...but my chev never did that.
I have messed with the caster/camber...little effect.
Changing over to the Toyo MT from the stock ones did make the ride a little softer.
I know adding weight will help..My chev did have a camper shell on it..I was thinking of that and maybe some sand bags..
It is NOT the death wobble I have. It is the up/down movement on the hiway which is worse at a certain speed but mellows out if you drive through it. but still rough.
OK, fire away..I need to do something..it is killing me.
You only replaced 2 shocks? Although I never believed it, a suspension system is just that...a system. You need to realize that everything you do to any part of it will have an effect somewhere else. Replacing 2 out of 4 shocks isn't recommended and many here have reported poor performance when doing so. This is usually corrected by matching all 4 shocks.
Yea, I hear ya..the only reason I replaced the front is because they were to short when I put the leveling kit on..I was reading on a few other threads that alot of folks have found the stock rear ones wore out and had the same symptoms..I am going to replace all the shocks and put a new steering stabalizer in it while Im at it...I'll let ya know how it goes. Thanks for taking the time do drop a note.
Without sitting in your truck I can't tell what your issue feels like, but many of the people on here with similar sounding issues have found the dropping the tire pressure actually makes it worse. I found that with my issue, lower pressure made it a lot worse. I'm going to have my tires road force balanced this week, so we'll see if that helps. If nothing else, I'll be able to get that part out of the equation.
Rally --
What brand of level springs did you install? You say Rancho shocks, but which ones...RS5000, RS9000's etc.?
IMO...with the condition you mention about the front bouncing...that is directly related to shocks. The 5100 series shocks by Bilstein are some of the BEST on the market.
So...you could also go with the following DR system. You will LOVE your SD again...
Link: http://www.donahoeracing.com/
Good luck...
biz
Originally Posted by donahoeracing
2.5" Leveling System
2005-2007 F-250/F-350 4WD
Part# 6-2500
Part# 6-2500
Good luck...
biz
I was looking at the bilsteins..I have a coil over setup on my R32 and love em..
The springs I bought are these ones
http://www.customsuspension.com/Gall...umName=album56
and the shocks I bought were the RS, which I think stand for "really suck"
The DR's are just overpriced...and I guess I am punishing myself for staying away from that company.
However, another question...you mention the Toyo MT tires. Did you also purchase new wheels (rims)? Because the best fit for those tires are a 10" rim.
The 35psi for a Load Range E tire is really NOT recommended. Maybe 50psi...but no lower...IMO.
Get the DR setup...as a lift system goes...You will be happy.
biz
According to Toyo the best width rim is 10". Back spacing? Don't know...sorry. Best cost for DR? Don't know that either...because it could change from one week to another. IMO...just Google DR sales and see what you find.
The (Bilstein) DR shock is properly tuned for there products, so if you go DR suspension then there shock works best. If you keep or go with a different setup for the lift, then the 5100 series would be your shock.
Hope this helps some...
biz
biz
samurai
1999 to 2016 Super Duty
10-31-2008 10:53 AM
