Paint hardener for rustoleum?
I use Valspar hardner for all the oil base paint I spray. It speeds drying and increases durability. I have used it with Valspar paint, which I like a lot more than Rustoleum, Rustoleum and custom matched paint I get from Sherwin Williams. It really speeds drying. I don't like Rustoleum because it dries so slow, even with the added hardener but at least with the Valspar hardener it dries in a day instead of two-three days.
I wouldn't use it with a paint that has it's own hardener, I would use the recommended product for that paint.
Originally Posted by WALFORD'S 56
I have had luck with ppg acyrylic enamel hardener in straight enamels and rustoleum and it dries faster with lacquer thinner--don't ask me how I know this,hahahah!!!!3:00 ON A SUNDAY NITE WILL MAKE YOU TRY ANYTHING,and sometimes they even work out!!!! Bill
I find the Valspar hardener helps the paint dry just as fast and also keeps the shine.
One more very important thing I forgot to say in my first post, the Valspar hardener is like any other paint additive hardener, it is pretty nasty stuff and can seriously injure your lungs so make sure you use a respirator.
Oil based enamels are very slow drying by nature, the paint cannot form a hard surface until all the heavy solvent has migrated thru or it will lift or peel, so enamels can take a week to a month to develop full hardness. Until then they can be soft and "tender" requiring careful handling.
I was just looking through one of my Sherwin Williams training manuals and there is an addditive called Multi-Flex it's a urethane Flexible additive that can be added to wide variety of paint products including acrylic enamel. It's designed for plastic bumbers but works great on anything that see's a lot of road abuse such as frames. It makes the paint flexible which helps prevent chipping. I remeber painting a raquet ball in class one time and when it was dry the paint flexed with the ball. I was impressed. Sherwin William P/N V6-V299 if your interested. I painted my steel bumpers with acrlic and hardner and the chipped up after five years I don't think I would've had that problem if I used the flex agent.
There may be a local automotive paint shop in your area that carries it If not, go here. Be aware, the hardenrs for urethane and enamel are different and we don't know what you're using..
Amazon.com: Valspar 4625 Enamel Hardener - 8 oz.: Automotive
I've been spraying paint with hardener added for years using a regular industrial filtered respirator. I don't do much, maybe 4-5 a year and haven't had any problems. I know I'm sensitive to the hardener, which is basically super glue, so I don't stay in area any longer than I have to but I have to get the work done.
The only time that I had problems was when I worked at my first body shop job. I helped my new boss paint a truck hood, we finished and he removed his.mask and I followed. He didn't have spray booth, we painted out in the open shop. By afternoon I could hardly breath. After that I never removed my respirator until I was outside and after the shop was aired out.
This how I do it and like.I said, I haven't any problems. Just because I do it doesn't I.promoting that anyone do it. Just telling what I do. I add Valspar hardener to all the paint I spray out of.my gun.
I use Chassis Saver and have had very good luck with it. Works like POR15 but is not ultraviolet sensitive. Flows out great and dries rock hard overnight.
Paint Over Rust to Stop Rust Permanently With Chassis Saver Truck & Auto Underbody Coating
