1994 Bronco Rearend
1994 Bronco Rearend
I just got a 94 Bronco with 102,280 miles on it. Seems to run good, but I noticed some play in the rearend. If you jack up the rear and pull or push on the wheels you get a slight movement in and out, definitely the whole wheel assembly. Is this common on the 8.8 rearend? I read something about spider gears on hear. Is this a symptom of bad spider gears?
Thanks Jason
Thanks Jason
Darksideforge
03-20-2017 07:48 AM
east302
06-15-2016 07:52 PM
Kadin Cook
03-24-2016 09:55 PM
gtotiger65
16
09-05-2015 09:33 AM
hayden01
11-28-2008 12:39 AM
