Anyone seen a Flatbed kit for an F150? - Ford Truck Enthusiasts Forums
Old 10-08-2007, 10:41 AM
southcarolina southcarolina is offline
southcarolina is starting off with a positive reputation.
I have "acquired" a wrecked 97 F150, it needs a replacement bed... but I am mroe interested in getting a flatbed for it if someone makes a kit that saves me some fabrication. Can anybody point me to a kit that is made for 97's or such? I could make one but I'd like to see if there is something functional for a farm type application.
Old 10-10-2007, 10:23 AM
Anybody??? no flatbeds eh?
Hmm... sounds like an opportunity here!
Old 10-11-2007, 05:29 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Well since FORD designed those "nifty" notches on the cab corners for the bed to fit into it would look kinda funny with just a flat bed. Of course you could form up some cab corners.....
Old 10-11-2007, 06:37 PM
GammaDriver's Avatar
GammaDriver GammaDriver is offline
GammaDriver is starting off with a positive reputation.
Yeah, I think you could cut a flatbed to contour up around, or into, those recesses. The curved front might look kinda cool, too.
A custom-cut bed-front would hide that, and protect the cab from a load moving forward.
Old 10-11-2007, 08:01 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
You might do what I did and find a solid used flatbed/stakebed and adapt it. I made some 2" tube crossmembers, bolted them to the frame of my '76, set the bed on them, and welded it in place. No alteration to the frame and very easy work.
That mount on ncrancheros frame with the angles over the sides (dump bed kit?) is a very strong way to go too. I have the same general setup adapting my Holmes 440 boom. Low, strong, and the angles halt lateral movement.
Check salvage yards and scrap metal places for big flatbeds you can trim (I Sawzall 'em) to size, as well as the Carolina Trader.
If you are near Sumter, Infingers is a convenient place to buy metal. I'm not affiliated with them, but they are nice folks with a good selection.
Old 10-11-2007, 08:09 PM
ncranchero's Avatar
Quote:
That's the under bed frame for the gooseneck hitch that was in the bed. I removed the hitch and frame before installing my "new" bed. But you're right, that frame is a REAL chunk of steel!
Factory flatbed truck to truckbed? 1978fordmoneypit 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-06-2014 01:24 AM
f-250 flatbed convertion redneckandy814 1973 - 1979 F-100 & Larger F-Series Trucks 15 07-21-2013 06:05 PM
Flatbed pics? j7angus 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-25-2011 07:07 PM
88' F150 Flatbed Plans chrono4 1987 - 1996 F150 & Larger F-Series Trucks 2 04-20-2004 10:06 PM
aluminum flatbed 150? bullhauler 1997 - 2003 F150 1 04-28-2002 10:41 AM
Tags
04, 2003, 97, bed, explorer, f150, flat, flatbed, flatbeds, ford, kit, long, replacement, size, sport, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
