water leaking thru top of rear window!! - Ford Truck Enthusiasts Forums
Old 10-08-2007, 02:35 AM
canucker canucker is offline
canucker is starting off with a positive reputation.
I have unfortunately discovered that rain is coming through the rear window of my truck. I wondering if anyone else has had this problem and if it was a big job to fix it. The caulking appears to be rotten and I'm wondering if some goop will seal it up. I'm just not sur e how to get the trim off!! Any help would be appreciated.
Old 10-08-2007, 06:44 AM
Joe Finn's Avatar
Joe Finn Joe Finn is offline
Joe Finn is gaining momentum as a positive member of FTE.
If you search, I think you'll find that this is a fairly common problem. Not sure what year Ford squared this away, I think 2000 or 2001. My '97 leaks a little bit when I wash it, but rain usually doesn't get in. I'm pretty sure the only real fix is to replace the window. I got a quote of about $250, just haven't gotten it done yet.
Old 10-08-2007, 09:09 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i bought a cauling tube of black silicone. pry the trim out 1/4 inch and filled it full from one end to the other. smooth it flush with your finger and wipe off any access. i ran down each side about 6 inches . cost $5. and took 20 minutes.
Old 10-08-2007, 03:03 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
Quote:
This seems to be the only cure to fixing the leak. The origional owner of my truck replaced the entire rear window and trim back when he had it, but it still leaks when I wash the truck.
Old 10-08-2007, 05:06 PM
redrumybronco redrumybronco is offline
redrumybronco is starting off with a positive reputation.
Pull the window out and re-seal it with rope sealant.... It will take you an afternoon to do it at best but well worth it.... clean the old stuff out. The hardest part is getting to the nuts above the window, behind the headliner on the roof.
Old 10-08-2007, 06:07 PM
02crew's Avatar
02crew 02crew is offline
02crew is starting off with a positive reputation.
you have to unbolt the window. it sealed with a tape called butyel tape. unbolt it and scrape out the old butyel than either use new butyel or urathane adhesive from a glass shop to re-install it. please dont use silicone it causes the metal to rust. most autoglass shops would do it for you for 75.00 to 100.00 but if you take it appart i bet they would do it alot cheeper.
Old 10-08-2007, 08:40 PM
Bobby82490's Avatar
Bobby82490 Bobby82490 is offline
Bobby82490 is gaining momentum as a positive member of FTE.
what size does the tape need to be?
Old 10-08-2007, 09:34 PM
02crew's Avatar
good question i think its 1/4 inch. the tape keeps the window from sinking in to much when you tighten it up. most glass shops will use the tape than back-fill it with urathane to provide a good seal. i see lots of trucks having windows replaced cause they leak. in mass we have no deductable on glass(most of us) so they end up getting replaced with new windows. but if your having a leak issuse i would just pry up the outside moulding and pump some sealent in. its messy,and chances are that your not going to get the spot thats leaking. if your going to go the cheep route seal it from the inside. you have a better chance of hitting the spot but i bet another one will turn up.
Old 10-08-2007, 10:06 PM
steve(ill)'s Avatar
seal an exterior leak from the inside?---- just fill the groove full of silicone and be done with it. do the whole length and it can not leak again. i did it years ago, took 20 minutes and $5.
Old 10-09-2007, 09:38 AM
02crew's Avatar
yes seal an exterior leak from the inside. it leaks into the truck right? i would hate to see what your backglass pinchwell will look like in a few years. silicone repaires end up causing more damage. silicone will rust and rot out the metal ive seen it before. but hay do whatever you want fte is here to help people not fix their cars for them.
Old 10-17-2007, 09:07 PM
backdraft529 backdraft529 is offline
backdraft529 is starting off with a positive reputation.
My 1997 F-150 Leaks From The Rear Window When I Wash It or It Rains. Might Have To Try The Silicone Trick.
Old 10-17-2007, 09:19 PM
steve(ill)'s Avatar
do it, it works. FORD has been using it for years to seal floor / joints/ firewall to keep water out and rattles down. great stuff and cheap fix.
Old 10-19-2007, 11:38 PM
02crew's Avatar
guys dont use silicone it has an agent in it that will cause the metal to rust if there is any bare metal behind the mouldings. go to a glass shop and buy a tube of urathane to seal it
Old 10-20-2007, 01:09 AM
Octane's Avatar
Octane Octane is offline
Octane is starting off with a positive reputation.
Mine rear window leaks too. I tried the silicone caulk fix and that reduced the problem, but the window still leaks a little. In my case its a very slight drip.
In my case, I think some of the water is coming in through the hole where the wire for the 3rd brake light goes through the back of the cab.
Either way, on a truck with 165,400 miles on it like mine, Im not going to worry about it. If thats the biggest problem my truck has, Im pretty happy.
Old 10-20-2007, 09:53 AM
02crew's Avatar
its hard to seal a leak from the outside cause you have to deal with the think plastic moulding that has nothing to do with the seal of the glass to the body. its better to seal it from the inside if your going the easy route. if a window is leaking chances are there is already some rust and the point im trying to make is that adding a silicone based sealant will only add to the rusting creating a worse leak in the future. hey steve what do i know anyway? ive only been in the autoglass field for about 16 years of my life (shrug) :.)
1939 Door Window Ventshades? Larry Garland 1947 and Older Ford Trucks 2 06-01-2016 08:44 AM
Rear sliding window seal notthemaniusedtobe 1973 - 1979 F-100 & Larger F-Series Trucks 26 04-02-2015 03:07 PM
Crew Cab window tinting jakgod3 1999 to 2016 Super Duty 17 06-25-2014 11:40 AM
Whats the Percentage of Tint that Everybody is Using? OVER_KILL Appearance & Dress-Up 30 11-12-2008 08:27 AM
Factory Tint on a 2000 Expedition: Whats the Percentage? OVER_KILL Expedition & Navigator 2 04-06-2008 11:01 PM
Tags
2001, 2002, butyl, f150, fix, ford, leak, leaking, rear, repair, shawn121074, shawn121074yahoocom, tape, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
