My headlight switch gave up, I ordered it and got a new one. It didn't come with the knob or the triangular post. Can I use the post/knob from the old switch? If so, how do I get the post out of the old switch? How much of the dash do I have to take apart to get to the switch? The new switch part number is SW - 2103 E7TZ-11654-B It's a 94 Aerostar with standard headlight controls.
There is a spring loaded retaining clip or a set screw that holds it in place. You should get a headlight relay kit as well, unless you want to fry your new switch. The switch can't handle the current of the headlights, and over time the switch will overheat and fail.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
Where can this said relay or relays be purchased? my switch doesn't get hot, but my new headlights draw alot of power, and i'm thinking of adding fog lights, and don't want to have a nuclear melt down on my dashboard.
__________________
93 3.0l xlt extended aerostar
mods:
800 watt sound system.
200+ farad kenetic battery + 875 cca reg. battery
2" catback exhaust w new flexpipe and cherry bomb muffler.
4g alt. wiring
Gutted stock airbox
2nd row bucket seats
The really old style headlights had a spring loaded button on the bottom of the switch body that you pushed to allow the light switch knob to be pulled out. Dunno about the new ones.
Someone recently posted a link to a ready-made harness for the 9007 series headlights. If you can't find it, you can check with Stern Lighting. These harnesses can be installed without cutting or splicing the stock harnesses.
If you can't find a pre-made harness for your car, you can find the parts from Radio Shack. They have a 1 cubic inch relay that handles 30 amps; you should get one for the high beam and one for the low beam. Also get fuses and 10 gauge wires, and some connection lugs.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Thanks BR. lol i should've posted that used the search feature and found the link under here, but thanks again! question: how long did shipping take for you?
__________________
mods:
4g alt. wiring
Gutted stock airbox
With me it was 7 days. Not the fastest, but I was a reasonable shipping time.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
The Ford parts supplier had sent me the wrong switch. I took the broken switch out, sprayed it full of contact cleaner, worked it back and forth. Reinstalled switch, its been that way till couple of weeks ago when the switch totally failed. Pretty amazing it lasted this long, 210K miles. New switch is now in place, had to use solderless terminals to replace the burned plug. Does anyone know the replacement plug Part number?
I'm pretty sure thay are the only ones still making that plug AC Delco does make good quality parts.
__________________
My Rides
175,000 miles
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
6C2Z11654A .. Headlamp Switch (Motorcraft SW6352)
Fits: 1994/95 Aerostar without automatic headlights.
> > 6C2Z11654A replaces E7TZ11654B < <
__________________ Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
