Any idea's or books for 460 build?
I am getting ready to build a 460 for my truck. It already has a 460 in it but the oil pump just seized up so i am looking to rebuild it. I have the dove heads already on it with a stealth intake. looking to keep my intake and 750 carb. Maybe some mild head work. i have looked for books on build ups but the only ones i find are only on stock rebuilds.
Any sujestion on a book or just what type of build would be helpful. The truck is a 78 crew cab with 36" tires and a C6. It is mostly used for towing. I am wanting to get torque out of the motor. Somewhere around 500 ftlbs or more.
Thanks,
Nate
Thanks,
Nate
HP Books "How to Rebuild Ford V8 Engines" by Tom Munroe is a great resource. I used another HP book "How to Rebuild Your Big Block Ford" for the FE engines and it was fantastic. It ised quoted references from some famous builders.
I think the V8 book has Holman Moody info, Jack Roush, etc. I have a few of these books and they are a fantastic resource. Gives casting numbers too.
Originally Posted by monsterbaby
only thing if you read Tom Monroes book disregard about 3/4s of it and anything about casting numbers completely he published a LOT of bad info in that book referencing casting numbers etc. But the basic building info in the book is good.
But the numbers I have taken from most of these books were spot-on and jived with other resources...
Of course, with the aftermarket, a lot has changed since these were published as fas as new heads, intakes, etc.
Mark not all are bad but there is enough bad info on casting numbers etc I always tell people to ignore that part of the book because it leads to a lot of misconceptions. Most of those books do real good on the SBC stuff but make a ton of mistakes on the ford stuff especially the big block stuff.
An example of a misconception found in some of the books is that you need to find a D8TE or D7TE truck block because they are 4 bolt mains, wrong NON of the truck blocks were 4 bolt and those 2 casting numbers never existed in reference to he 385 series engines.
I really like the Lunati #96 cam I put in mine, but it isn't stroked. I didn't use their lifters though. They are outsourced & of poor quality I was told, so I got a set of Reed's anti pump ups. Reed doesn't make them. Their either Federal or Johnsons reboxed. I gobbed it up real good with Isky Rev-Lube and put a bottle of Crane's additive in & didn't have any problem with break in.
