1961 pickup
Old 10-22-2007, 11:16 PM
drialec's Avatar
drialec
drialec is offline
1961 pickup
just picked up a 1961 5 window.. anyone know where to find wiring harnesses?? it looks like a mess under the dash and i'd like to get some new stuff.. thanx mike
Old 10-23-2007, 09:51 PM
66gpw's Avatar
66gpw
66gpw is offline
Sorry don't know anyone who sells replacement harnesses. I had to take the harness out of 3 econolines and stretched them out on my lawn and open the harness up to make one good harness. I was forntunate at the time to get a copy of a wire schematic which I have since misplaced.
That is the best right now is to get another harness and if you can find a wire schenatic. Make one good harness.
Maybe someone else may know where to get a harness or help with a schematic to help you sort the one you have.
Old 10-23-2007, 10:19 PM
Ole' Green's Avatar
Ole' Green
Ole' Green is offline
For what its worth, I've had really good experiences with EZ Wiring kits. As long as youre not looking for concours, stock, its a simple installation (as simple as it can be, anyway), and very inexpensive.
I would get the 12 circuit kit for the truck, wires are marked every couple of inches, you can build a mounting plate to mount the fuse block to, it really cleans up under the dash.
IF you decide to build your own, make two of them, one for a '64 van!!!
Good luck,
Ole Green
ivanogburn
07-17-2007 12:55 AM
67 scoob
04-25-2002 04:14 PM
NELLS
07-28-2001 02:20 PM
Phil
10-14-1999 03:10 PM
Quick Reply: 1961 pickup
