E250 5.8 gas mileage - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 10-07-2007, 01:07 PM
WorkVan58 WorkVan58 is offline
WorkVan58 is starting off with a positive reputation.
I have an '92 E250 with the 5.8 motor. I'm a contractor and I use this for work, so it probabley has from 1200 to 1600 lbs of tools and materials in it at any given time. I get about 9 miles per gallon driving mostly city. Is this about all I should expect for this van ? Would a newer van with the 5.4 motor get a decent amount more gas mileage ? What are you getting in your E250 ?
Old 10-07-2007, 08:19 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
my e-350 gets 10 to 11 mpg
only driven around town
about 2000 lbs. in back
I'm a carpenter
my previos e-250 with 351 was the same
took on a 600 mile round trip and got 10.5
over a 4 day weekend
Old 10-13-2007, 02:18 AM
glasstruck glasstruck is offline
glasstruck is starting off with a positive reputation.
9 mpg....not too bad in my book, considering I'm getting about 9.5 in my E-250 extended cargo with the V-6 ('99). The van is carrying exterior aluminum glass racks on both sides of the van, plus a bunch of tools inside. I know I'm working that little motor pretty hard, but it's holding up fine!
Jim
Old 10-14-2007, 08:10 AM
I just calculated what mpg I was getting on my last tank of gas - 9.9 mpg. That was doing about 75% city 25% highway driving. The van weighs 6500 lbs with the tools I have in it now plus me in it.
The van is rated 10 city 13 highway so I'm pretty happy that I got 9.9 mpg on a van with 116k on it.
Old 10-21-2007, 05:43 PM
Skiall6 Skiall6 is offline
Skiall6 is starting off with a positive reputation.
My 97 E-250 extended van w/4.2 ltr V-6 just got 16.5 on a trip to Atlanta and back to Orlando. I turned the air off and watched my speed, being careful to not get over 75 mph.It normally gets around 11 mpg around town. This van has 229,000 miles and still runs strong and looks new.
Old 10-21-2007, 10:18 PM
Econoline 150's Avatar
Econoline 150 Econoline 150 is offline
Econoline 150 is starting off with a positive reputation.
Quote:
Just my .02 on the whole thing :
I think regardless of make a large V8 van wont do to well. Sad fact is gas prices are through the roof and guys like you need a large vehicle to haul your equipment around and from what my friend tells me (hes a contractor also ) its really hitting his wallet.
Old 10-21-2007, 10:53 PM
Skiall6,
How much weight did/do you carry around in your van ?
Old 10-22-2007, 05:06 AM
Skiall6,
I am a Tile and Marble Contractor. There is usually 1000 lbs of tools in my van at any given time. I also have a 2005 F-250 diesel King Ranch that I use to haul my materials. Pallets of tile and stone are too much weight for the V-6.
Old 10-23-2007, 03:25 AM
Well I just cracked the 14 mpg barrier on our '06 E-350 extended diesel. Up to this point, it was getting about 13.5 mpg. It's only now got 15k miles on it, so it might improve, or so they tell me. I try to keep my foot out of it, but the power is addictive, especially after driving my '99 E-250 v-6 extended around! I don't even think about passing people with the v-6; it barely holds 55 in overdrive, but it's loaded pretty much all the time, with wind resistance to boot (glass racks, ladders up top, etc.).
Jim
Old 10-24-2007, 08:18 PM
My last 3 tanks I averaged 10 mpg, so I'm pretty happy.
Until I put a new timing chain on it I was only getting 5-7 mpg. The timing chain was so loose the timing was retarded 18 degrees from what it should have been. It was like that when I bought it.
Old 10-25-2007, 07:53 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
2005 E250 4.6L w/4.10 gears & 187000 miles.
I run 500 miles every Tuesday with 1000-1500+ lb load. Interstate @70 - 75 gets 17.4 +/- . Last two trips I went 4 lane state roads, 55 mph and under, 18.0 mpg both times.
Got my new '08 yesterday 5.4L w/3.73's. Curious how it will do......
Old 10-26-2007, 05:01 AM
bobbyv bobbyv is offline
bobbyv is starting off with a positive reputation.
my old but tried and true 95 Sportsmobile E250, auto. 5.8 3.73 posi., w/134,000 mi. gets 11-12 mpg pretty much anywhere I go. Put it on the scales last month, and the total weight with all tanks full was 7,546 lbs. It still looks and runs like new, so I'm OK with it considering all factors. Thanks Ford.
Old 10-29-2007, 05:43 AM
Dannym Dannym is offline
Dannym is starting off with a positive reputation.
Quote:
Ha mine is more tried and true- '87 Sportsmobile E150! 5.0 302. So that's before Ford smoothed out the front end to make it a bit more aero. Mine's got the Sportsmobile "Penthouse" popup top that only raises the roof like 3" or so while driving. It's got all the great stuff (water tank, fridge, batt, propane system, stove, beds, etc and I keep tons of crap in the back on top of that. I get a bit over 13 mpg on the highway if I keep it around 65-70. Trying to keep 75 mph is tough and eats gas. Around town's definitely more like 10.
Old 11-05-2007, 08:29 PM
MuddyAxles MuddyAxles is offline
MuddyAxles has a good reputation on FTE.MuddyAxles has a good reputation on FTE.
For comparison's sake:
'06 E-350, V-10, 5-sp, Quigley 4x4, 3.73's, almost 24,000 mi., scales at about 6,900 as driven. I average about 13 m. p. g. mixed country 2-lane (55-60) and expressway 65-70) driving, some city, mid-12's if I push it a little harder.
On trip recently towing tandem axle trailer weighing just shy of 3,000 empty, on US 20 across central New York state still got over 10 m. p. g.
The only load I moved was about 3,000 lbs over 45 miles, so I couldn't get a good m. p. g. read from that.
The '89 E-250 w/ 351 got 15 m. p. g. consistently, not loaded heavily.
The '95 E-250 w/ 300 I-6 got 16 m. p. g. at best, loaded the same.
Old 11-06-2007, 10:25 AM
Jim_Becker68 Jim_Becker68 is offline
Jim_Becker68 is starting off with a positive reputation.
My 01 E-350 15 passenger filled and hauling a car on a trailer did about 12 mpg over the highway.
Not loaded and highway driven it does about 15 mpg or so. It actually depends on the weather. Wind speed on this large van really plays a big factor in mileage.
City and empty or lightly loaded it rumbles around 12-14 mpg.
Jim
Motor Swap Issue dudef150 1987 - 1996 F150 & Larger F-Series Trucks 3 12-14-2014 06:24 PM
Switching Motors? dudef150 1987 - 1996 F150 & Larger F-Series Trucks 6 11-28-2014 09:48 AM
97 F250 5.8 poor gas mileage racerdon 1987 - 1996 F150 & Larger F-Series Trucks 3 09-23-2012 07:55 AM
95' E-150 5.8 gas milage babbler 1968-2013 Full Size Vans 13 03-07-2006 07:59 PM
5.4ltr/5.8ltr tossup 73F100*8Mile 1968-2013 Full Size Vans 2 08-29-2005 10:47 AM
Tags
07, 355, 410gear, 58, 80mph, day, e250, ford, mpg, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
