Idles good in park,bad in drive
Old 10-07-2007, 07:35 AM
adeese660's Avatar
adeese660
adeese660 is offline
I have an 01 F150 with the 4.6L,the problem i have is when i start the truck,it idles good,untill i put it in gear,then it kinda surges while stopped,when i accelerate,it shakes and shudders real bad,untill i get to cruising speed,it still does it then,but not as bad,i can turn off the overdrive to keep rmp's up during cruising speeds,and it allmost goes away.The CEL is not on.But it runs bad,to the point I am embarresed to drive it.
Old 10-07-2007, 11:21 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
Have the spark plugs been changed? Fuel filter? Air filter? Do a tune up on it and see where that leaves you.
Old 10-07-2007, 11:26 AM
adeese660's Avatar
adeese660
ok,ill try that,do you know where the fuel filter is on this truck?
Old 10-13-2007, 02:52 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
It is inside the frame rail right about where the D. side door is.
I have roughly the same problem and have replaced the IAC, cleaned the MAF, had a motorvac and still the engine stumbles at idle in drive. Today it actually quit on me. I am wondering if a bad COP could cause this. The first time I had one go bad it stumbled under a slight load and at times idled bad. Mine runs fine as long as it is not stopped in Drive, even turning on the AC will help on mine, must bump the idle up just enough. I also have no CEL and no codes.
Old 10-14-2007, 06:48 AM
adeese660's Avatar
adeese660
Thanks for the info on the fuel filter.I am beginning to wonder if the rain has something to do with it running bad,I dont use the truck at all during the week because I have a co. truck,so her is the story.We have not had much rain here,then last week we finally got some,before the rain it ran good,the problem started last Sat while it was raining,I did not drive the truck again till yesterday,Sat,when I started it,it ran great,it has not rained since last Sat,so I wonder if the rain may be causing a problem someway,either way,i am changing the plugs,all COP's,fuel filter and air filter,,but my question now is,do you think the rain may have a part in this?
Old 10-14-2007, 05:48 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Sounds like there is either water getting past the hood seal in the rear allowing water to get into the plug pockets or the humidity is causing a misfire. I would remove the coils and install dielectric grease on the boots.
Old 10-15-2007, 02:13 PM
Fishin76's Avatar
Fishin76
Fishin76 is offline
If the cops are bad (no pun intended), the humidity coould have seeped in and corroded the insides. Water and the cops don't mix well.
Its just like an old dizzy and worn out plugs. run good at speed, terrible at idle and under low speed load.
Old 10-15-2007, 07:24 PM
adeese660's Avatar
adeese660
Well,i think what i will do to be on the safe side,is to replace the plugs,air filter,fuel filter and the COP's.But now,I have a question about quality of the COP's.Are the ones on e-bay that Global-Automotive sells,are they any good,I am buying Motorcraft plugs,but was wondering about the quility of these COP's.
Old 10-15-2007, 10:22 PM
galaxie641's Avatar
galaxie641
I assume you are talking about the 8 for around $110, as in expensive as they are compared to around $60-$80 for 1 from the dealer I don't think you can go wrong with them. There are even name brand COP's now being sold for around $25ea. out of summit.
Old 11-03-2007, 03:08 PM
adeese660's Avatar
adeese660
I finally got around to putting all plugs,COP's,air filter and fuel filter>what a differance it made.I just want to thank all of you for your help.I never realized how much power I have lost over time,it has alot better throttle response now,and the miss is gone,again,thank you for your help
cberr
1997 - 2003 F150
07-19-2016 03:53 AM
davem77f150
04-19-2016 01:18 PM
PD slaughter
General Diesel Discussion
03-17-2016 08:12 PM
areyou4real
Aerostar
26
11-09-2015 05:19 PM
mebe2k
15
09-11-2015 01:47 AM
Quick Reply: Idles good in park,bad in drive
